GWR Infrastructure
Dazza3732
8 Nov 2015
Hi.
The GWR mainline from Exeter St Davids down to Penzance does it still have semaphore signalling and Absolute block sections or is it all colour light TCB now??
Many thanks Darren.
Harbornite
7 May 2016
Hi.
Many thanks Darren.
There are semaphores in the Par area.
455driver
10 May 2010
Lots of semaphores and lots of AB as well.
It starts at Liskeard and extends down to St Erth.
Dazza3732
8 Nov 2015
Cheers.
On Absolute block, if your train fails is it emergency protection or just assistance protection?
6 Sep 2011
Blackpool south Shore
Haven't been down there for a while. Signal boxes with semaphores still open, Penzance, St Erth, Roskear Junct (controls level crossing, and cctv crossing at Camborne Stn (plunger on up platform before coloured light signal) Truro, Par, [Newquay branch - St Blazey, (2 cctv crossings) Goonbarrow Junction] Lostwithiel, Liskeard.
Railsigns
15 Feb 2010
Not Penzance.
julianblack
24 Oct 2015
I was there in late 1981/early 1982 as they were installing the colour light signals. That was only a couple of years ago, wasn't it??
Johnuk123
19 Mar 2012
You wouldn't think in this day and age the railway would STILL have little arms on posts that go up and down, so incredibly antiquated.
coppercapped
13 Sep 2015
Reading
Have you thought about why this might be the case?
(Low traffic density, earnings/train not being very high, longevity of mechanical signalling, and so on...?)
(That modern business of air transport still uses men holding little bats to guide aeroplanes, even more antiquated...)
Johnuk123
19 Mar 2012
We've had colour lights since way before WW11 we shouldn't still be using them, they are from a time of horse and carts.
sciisfun
28 Aug 2015
south west
Apart from when they use cars with boards that say follow me!
not my image, just one of the first of google
So if its old we shouldnt use it? Even if it works and has no justification currently to be replaced?
455driver
10 May 2010
Thats me out of work then! :lol:
Cheers.
Contact controlling signal box and act on instructions, we do have GSM-R you know! ;)
Johncleesefan
4 Sep 2013
Nowt wrong with semaphore and ab. No point investing millions to upgrade unless its proving unreliable or the section is being upgraded.
Dazza3732
8 Nov 2015
Contact controlling signal box and act on instructions, we do have GSM-R you know! ;)[/QUOTE]
Cheers :) but sometimes the pesky GSM-R can put you through to the wrong box..
XDM
9 Apr 2016
Are dazzler & 455 the same. I know there is only one correct answer,
But exactly the same words including the!
455driver
10 May 2010
We have a few areas where we can get any one of 3 signalboxes, what waswl wrong with CSR which told you (with the area code) which signalboxes you were connected too.
ComUtoR
13 Dec 2013
Er... GSMR will tell you which signaller it connects to. Also, you should, with good route knowledge, know which is the correct Signaller you need to talk to. Mostly they follow the old CSR area codes so when the area changes so does the box/panel. You should also have a clue by the signal plate. I have a map of the GSMR panel numbers for my TOC area.
455driver
10 May 2010
do you mean the fact that dazzler has got the quote of my previous post wrong so it looks like we have posted exactly the same thing?
