ATW158Xpress
- Joined
- 6 Dec 2016
- Messages
- 287
Lots of HST’s on South Wales diagrams today.
Are there? So far today I have only picked up the following as HST with everything else being an IET. Are there some that I have missed?
1B20 0945 Paddington - Swansea
1B37 1315 Paddington - Cardiff
1B42 1415 Paddington - Cardiff
1B46 1445 Paddington - Swansea
1L08 0458 Swansea - Paddington
1L66 1329 Swansea - Paddington
1L74 1556 Cardiff - Paddington
1L82 1656 Cardiff - Paddington
That's curious because the down train to form the 1756, the 1515 Paddington - Cardiff, shows up as a 9-car
1B48 PADTON CRDFCEN 2 16:40 On time 16:41 On time
Last report: Arrived at Swindon (16:12)
This train has 9 coaches. 1st class in the front 2 coaches.
I believe the 1756 Cardiff - Paddington is a booked a HST
It's more of a gradual decline. The current base plan (which is being validated as I speak) has 3 diagrams going on 22/10, 1 on 05/11, 3 on 19/11 and 2 on 10/12. However, to finish using OOC from 10/12, a couple of current SG-SG 800 workings have to temporarily revert to being SPM-SPM HST to release enough 9 cars so there is a bit of a swap round on 10/12/18. Wales will still see a (very) few HST workings per day. A Penzance starter should commence from that date too.
The aim in that plan is to only have 13 SX HST diagrams as from 10/12. After Xmas, with all the Scotrail units gone and OOC vacated, the pace of replacement can, at last, slacken.
The draft diagrams for 22/10 are planned as follows - usual comments about STP alteration for engineering works apply. For brevity, train reporting numbers only;
(WOS) - 1L10 - (NP) - 1G60 - (SG).
(SG) - 1G02, 1L36, 1C12, 1A20, 1B55 - (MAL).
(MAL) - 1L20, 1G21, 1L58, 1B48, 1L88, 1W39 - (WOS).
For 5/11 the planned working is;
(MAL) - 1L14, 1C07, 1A15, 1C16, 1A24, 1B76 - (MAL).
That's it for now.
As far as I can tell they are allowed, and can certainly make it, to Penzance, it's just that the 800 engines are set to slightly less power than the 802, so they warm up a little more than usual up the banks. I may well be corrected of course.Sorry if this has been asked already, I thought 800's wern't cleared for Cornwall as they have lesser powered engines than 802's, I'm sure 800 316 is currently on its way to Penzance?
The oldest IEP infrastructure specifications I could find on DFT website included all sorts of routes including Penzance. I think later quarterly EDP details also always included gauge clearance to Penzance, however the original GWR trains were not “normally expected” to go to Penzance. In 2014 or so it was up in the air whether they would keep a small HST fleet for most through “Devon and Cornwall” services, but IIRC that didn’t apply to Paignton - which was to see IETs anyway. Never as black and white as sometimes thought.Sorry if this has been asked already, I thought 800's wern't cleared for Cornwall as they have lesser powered engines than 802's, I'm sure 800 316 is currently on its way to Penzance?
the 802 climbed the banks better as had more grunt.
Unimpressed with GWR's removal of 8 carriage HSTs in favour of 5 carriage IETs on the Cotswold line.
Even during off-peak weekday services there is standing room only.
Yes we are recording much better performance from the completely 'unmuzzled' 802's compared to the 800's in both electric and diesel modes. In electric mode the 802's are not subject to the DFT specified acceleration curve - so 100mph is coming up in less than 2 mins and 125mph in 3min 15 secs - impressive stuff.
In diesel mode the sprint to 40/50mph is similar, maybe a fraction quicker, but then they pull more strongly to 125 mph. Acceleration doesn't match a HST between 50 and 125mph, but the initial burst to 50mph more than makes up for the slower later acceleration. And they do seem to be a true 125mph unit now - with the full 940hp per motor!! The 800's would balance around 118/119 mph and could get to 125mph downhill.
802's will do 125mph - no problem on the flat!
IET also replaced 5 car 180's on some routes!Departing PAD it's often fully loaded in the weekday afternoons (not peak services). This is where the IET has replaced what used to be an HST so a drop in capacity.
Which makes sense. What doesn't make sense is 8 car HSTs being replaced by 5 car IETs.IET also replaced 5 car 180's on some routes!
Except in Cornwall.But no HST have in the LTP. They have all been replaced by 9 or 10 car IET.
With regard to acceleration under 25KV - not discussing diesel here -Out of curiosity - how does the electric mode performance of an 802 compare to a Pendolino?
