Railperf
- Joined
- 30 Oct 2017
- Messages
- 2,941
Any 802's diagrammed today? (weds 14th)
Thanks. Are any 802's out this coming Saturday?802 diagrams as follows, all 5 Car Class 802:
IW950
5C48 15+08 LA – PLY
2C48 15 57 PLY – PNZ
2E89 19 16 PNZ – PLY
5Z89 21+24 PNZ – NP
IW951
5A72 05+10 LA – PLY w/IW960
1A72 05 53 PLY – PAD w/IW960
DETACH
1D20 09 50 PAD – OXF
5P26 11+07 OXF – OXF
1P26 12 01 OXF – PAD
5P26 13+20 PAD – NP
ATTACH
5C89 15+58 NP – PAD w/IW960
1C89 16 33 PAD – EXD w/IW960
1A98 19 55 EXD – PAD w/IW960
5A98 23+03 PAD – NP w/IW960
IW952
5C71 06+06 NP – PAD w/IW961
1C71 06 35 PAD – PNZ w/IW961
1A88 12 04 PNZ – PAD w/IW961
5A88 17+38 PAD – NP w/IW961
IW954
5C80 11+20 NP – PAD w/IW963
1C80 12 03 PAD – PNZ w/IW963
1A35 17 42 PNZ – PAD w/IW963
5A35 00+06 PAD – NP w/IW963
IW955
5C04 07+06 NP – PAD w/IW964
1C04 07 30 PAD – PNZ w/IW964
1A93 14 00 PNZ – PAD w/IW964
1C96 20 03 PAD – PLY w/IW964
5C96 00+42 PLY – LA w/IW964
IW960
5A72 05+10 LA – PLY w/IW951
1A72 05 53 PLY – PAD w/IW951
DETACH
5A72 09+32 PAD – NP
ATTACH
5C89 15+58 NP – PAD w/IW951
1C89 16 33 PAD – EXD w/IW951
1A98 19 55 EXD – PAD w/IW951
5A98 23+03 PAD – NP w/IW951
IW961
5C71 06+06 NP – PAD w/IW952
1C71 06 35 PAD – PNZ w/IW952
1A88 12 04 PNZ – PAD w/IW952
5A88 17+38 PAD – NP w/IW952
IW963
IW964
5C04 07+06 NP – PAD w/IW955
1C04 07 30 PAD – PNZ w/IW955
1A93 14 00 PNZ – PAD w/IW955
1C96 20 03 PAD – PLY w/IW955
5C96 00+42 PLY – LA w/IW955
PAD = London Paddington
NP = North Pole IEP Depot
OXF = Oxford
EXD = Exeter St David’s
LA = Laira T&RSMD
PLY = Plymouth
PNZ = Penzance
EDIT: Formatting
Thanks. Will look out for them.I’ll post details in the morning. I’m just off to bed!
The current status for three of today's nine 802 diagrams;
09:50 London Paddington to Oxford due 10:49 has been cancelled.
This is due to a fault on this train.
Last Updated:16/11/2018 09:55
12:01 Oxford to London Paddington due 12:59 will be cancelled.
06:35 London Paddington to Penzance due 11:36 will be terminated at Newbury.
It will no longer call at Taunton, Exeter St Davids, Plymouth, Liskeard, Bodmin Parkway, St Austell, Truro, Redruth, Camborne, St Erth and Penzance.
Last Updated:16/11/2018 07:52
12:04 Penzance to London Paddington due 17:15 will be cancelled.
Last Updated:16/11/2018 08:45
The 06.35 & 12.04 are on the same diagram (IW952). Engine issues so terminated at Newbury.
Are any 9-car 802s assigned any diagrams yet?Als, how many 802s are currently available to cover those diagrams. I counted 9 diagrams in total802 diagrams as follows, all 5 Car Class 802:
IW950
5C48 15+08 LA – PLY
5Z89 21+24 PNZ – NP
IW951
DETACH
5P26 13+20 PAD – NP
ATTACH
IW952
IW954
IW955
IW960
DETACH
5A72 09+32 PAD – NP
ATTACH
IW961
IW963
IW964
OXF = Oxford
LA = Laira T&RSMD
PLY = Plymouth
PNZ = Penzance
EDIT: Formatting
Would they have let 006 and 011 continue to Oxford? Or did the uncoupling attempt cause other issues?No, both diagrams covered (so yes 3 diagrams affected by issues.)
802006 & 011 were the pair that should have split with 006 working to Oxford and back.
802005 & 010 were the pair in trouble at Newbury.
IW950
5C48 15+08 LA – PLY
5Z89 21+24 PNZ – NP
IW951
DETACH
5P26 13+20 PAD – NP
ATTACH
IW952
IW954
IW955
IW960
DETACH
5A72 09+32 PAD – NP
ATTACH
IW961
IW963
IW964
OXF = Oxford
LA = Laira T&RSMD
PLY = Plymouth
PNZ = Penzance
EDIT: Formatting
Seems to have been a bad morning in general on gwr. A quick scan of real-time trains seems to indicate delays on most inbound and outbound services.The current status for three of today's nine 802 diagrams;
I know 9 cars work up thru Oxford but would a 10 car cause issues?
I saw a 9-car in P4 at Oxford the other day, and it looked as if there was enough room for a 10th car in the platform there at least …
Am I right in suspecting the units terminated at Newbury were stuck in turn around mode?The 09.50 & 12.01 are on the same diagram (IW951). Paired with IW960, should have split at Paddington but had issues.
Will 1A80 (on a saturday) be an IET tomorrow?
Diagrams already show that one should be running yet last week a HST showed up, although thankfully the displays mentioned missing a coach H and J.
Can only presume that as 011 was due to layover at North Pole while 006 worked to Oxford and back that Hitachi wanted them both back on Depot. I know 9 cars work up thru Oxford but would a 10 car cause issues?
Yes - based on what I have seen on recent trips out, the London end unit - 802 011 in this case - would run to North Pole and be coupled to another 802 and would have formed the 12.03 Paddington to Penzance.
Do we know what the 12.03 ran with today?
I don’t think any have been issued yet. Isn’t 802101 the only one handed over and available for traffic. It quite often deputises for a 10 car. I don’t know how many 802 5 cars have arrived. The highest I’ve seen noted is 802016 and probably because that one was the one involved in the big dewirement.
I was just reporting on what seems to be actually happening - at least on the two occasions on which I have observed both the 09.50 and 12.03. Not sure if it's relevant but on both occasions it was a Monday.If you look at the diagrams that @JN114 provided at #1562, 006 & 011 would have been recoupled at NP and then worked the 1C89 16.33 Paddington - Exeter.
However that's not to say that Hitachi don't swap the sets, between diagrams, when on depot. Obviously a lot depends on engineering requirements or yard constraints.
Thanks v much @FGW_DID . I caught the 2003 pad to plymouth ..and indeed it was a pair of 802's 006 and 021 iirc. Was it 800 027 on the 1752 pad oxf?@Railperf
(IW952/IW961)
North Pole > 1C04 > 1A91 > 1C96 > LA
(IW958/IW967)
LA > 1A77 > 1C81 > 1A35 > NP
Usual disclaimers apply: operational requirements / unit availability etc etc
Hi @FGW_DID .. just confirming these 802 diagrams should be active this week?802 diagrams as follows, all 5 Car Class 802:
IW950
5C48 15+08 LA – PLY
5Z89 21+24 PNZ – NP
IW951
DETACH
5P26 13+20 PAD – NP
ATTACH
IW952
IW954
IW955
IW960
DETACH
5A72 09+32 PAD – NP
ATTACH
IW961
IW963
IW964
OXF = Oxford
LA = Laira T&RSMD
PLY = Plymouth
PNZ = Penzance
EDIT: Formatting
1c04& 1a93 is hst Monday-friday this week.Hi @FGW_DID .. just confirming these 802 diagrams should be active this week?
