GWR Paddington - Driver
SA91
9 Apr 2018
Hi,
Can anyone shed some light into GWR Paddington depot? How is GWR to work for? How is Paddington as a depot? Earliest starts / latest finishes? Sundays inside or outside? Taxi services? How many links? Maximum possible turn lengths? How often are night turns?
The Aslef company info page seems to have disappeared so can't check certain basic T&Cs...
Any info would be much appreciated.
Cheers.
Southern Dvr
13 Oct 2010
Hi,
Cheers.
Are there vacancies?
martin2345uk
21 Sep 2011
Essex
The "Company Information" is still there on the ASLEF site but you have to log in to see it
tiptoptaff
15 Feb 2013
Without knowing the specifics of Paddington, GWR don't offer any form of taxi agreement. Wholly your responsibility to get to/from work
martin2345uk
21 Sep 2011
Essex
Ah sorry yes, it's a known issue with the site, that page only displays correctly on desktop at the moment.
Does this imply there are companies out there who get drivers taxis to get to work..??
beany
17 Nov 2015
Paddington split into 2 depots.
HSS and GWR LTV.No more drivers will join HSS.So all new starters and transfers go into LTV.
3 links plus dynamic link which sign Bristol,when more drivers needed for Bristol then taken from link 1.
9hr 30 max length of shift
Sundays outside.
Sundays allocated but Paddington drivers have local agreement to opt out of booked turn,these are then covered by volunteers and then by other depots.
Earliest start is 3am.
There are Night shifts but not many.Think these finish by 5am.
Rest days on 3 week cycle,
Mon and tue
Wed and thur
Fri and Sat
So every 3rd week is 5 days off (you are never allocated a Sunday in the middle of the 5)
Majority of LTV drivers at Paddington have a permanent swap for earlies or lates.
New drivers will sign 800,165/166,387
Routes are Oxford,Newbury,Bedwyn,Reading
Branch lines Slough-Windsor,West Ealing-Greenford
SA91
9 Apr 2018
Sundays outside.
Mon and tue
Wed and thur
Fri and Sat
Brilliant, cheers.
tiptoptaff
15 Feb 2013
Yep, there are indeed companies with taxi agreements.
Eurostar even provide hotels
800 Driver
30 Aug 2019
Hi,
Cheers.
Pointless asking earliest starts / late finishes as they change every timetable change. However we usually have starts starting from 02.xx and turns finishing as late as 04.xx - plus night turns (we sign 3 depots to take trains from and to). Most drivers (2/3) do permanent swaps to either lates or earlys.
Sundays for any new drivers will have a level of commitment (but you don't have to work all your rostered Sundays) basically about 1 in 2 are rostered but you'll only have 1 in 3 commitment (so you'll get some wild passes for about 8 Sundays a year) - drivers pre 2018 harmonisation have no commitment. If you find someone to cover any Sunday you are committed to you won't have to work it and there's normally volunteers.
There are 3 links, one of which is more long distance (Bristol via Bath and Parkway, with Cheltenham and or Cardiff likely to be added soon). Link progression is by volunteering, with seniority used if there are too many or too few applicants for progression.
Generally the GWR depot is really friendly and chilled and people look out for each other. No comment on the HSS one.
Max turn length is 9h30 (8h45 for pre 6am starts) - most of the work is 800s to Bedwyn and Oxford with a few 387s thrown in and Greenford and Windsor branches. Of the 2 LTV links the top one tends to have more 800s and fewer branches. There's also a lot of shed and ferry to and from North Pole. So it's a nice balance of work. 800/802s, 387s, 165/6s plus Paddington will also learn ETCS L2 for taking the Hex 387s to Reading TCD for when they extend ETCS coverage from Airport Junction to Southall and then Acton from September.
SA91
9 Apr 2018
Amazing stuff thank you. Yeah I agree with the starts and finishes. Just wanted to have a rough gauge of the times. The additional work you mentioned coming September sounds interesting.
