- Joined
- 7 Apr 2010
- Messages
- 31,434
Sounds pretty categoric.The Bedwyns are staying Turbo, for now. Use of guards on 800 units doing the Bedwyns is wibble.
So the suggestion in wnxx on Saturday wasn’t legit?
IETs can run DOO to Newbury, as they are dispatched by Platform Staff there.
Are there enough Reading guards/TMs that sign the route to Newbury/Bedwyn?
Presumably 0609 Newbury - Paddington isn't DOO as that train has been an IET for a couple of months or so
There is engineering work in the Portsmouth area this Sunday 9th December. Can anyone confirm if it is in connection with the Turbo clearance to Portsmouth Harbour?
The main thing (still) is that the closure area on the 9th is far greater than needed to do the gauge clearance work at the Harbour. It’s more a case of just doing the work as a small add on during an already planned routine closure, for all the usual reasons, such as structures, S&C, third rail work, track renewal etc etc.The question has been asked more than once already in the thread together with some discussion but a definitive answer doesn' t appear to have appeared
More Turbos cascaded to the West today.
http://www.realtimetrains.co.uk/train/V56558/2018/12/31/advanced
p.s. Which units are on the move?
205 is the one that received the GWR interior isn't it?166203 on short term emergency loan to the west to cover for 166205 involved in a fatality yesterday. 166205 is on RTCD for post-incident work; moved as 5R71 1440 Bristol - Reading yesterday.
Will only be west for a few days until 205 is sorted.
Correct. All the others still have the FGW interior.205 is the one that received the GWR interior isn't it?
Interesting, and, as you say, at last! I have been asking GWR for months what they are doing about the North Downs line stock. The GWR corporate first class markings are dire anyway, and could so easily be good if a proper yellow stripe was applied (as with the final FGW style) instead of the pencil silver line, plus window stickers, etc. The seats have various cables hanging loose (presumably the seat lighting) and the whole environment is poor.I had 165114 to work today, and Interestingly I noticed that it has finally, after some persistent nagging from no doubt myself and others finally had the first class area tatted up at last. Newly painted walls, new FGW Moquette and new FGW first class carpet. They have even fitted new cushions and fixed the overhead lights at last. I’m impressed GWR, at last, well done.
I believe there starting with only 2 diagrams atm with being the 07:30 and 09:30 diagrams from Cardiff if this helps and then follow them on RTT for rest of the day.Turbo units to start running to/from PMH from this Friday (4th) - certain diagrams only. We have been told at work this afternoon.
Is it possible to have an up to date list of 165/166s Allocated to St Philips Marsh Bristol please?
I would make that the following departures from Portsmouth
1F16 11:23 PMH - CDF
1F20 13:23 PMH - CDF
1F34 19:23 PMH - CDF
2M95 21:23 PMH - WSB
Correct for Mon - Fri, also quoted is 1F18 12:23 PMH - CDF formed of 150+158 units.
Saturdays:
1F10 08:23 PMH - CDF
1F28 16:23 PMH - CDF
Nothing mentioned for Sundays.
How many Turbos will be released by the services which have swapped to electric in the past few days?
