with their superior acceleration and top speed.
The latter isn't currently available for use in passenger service.
As I understand it, some of the Class 802 order is for Oxford fast services.In practice, the xx:50 turbo departure to Oxford (calling at Slough) is almost always caught by the xy:00 departure to Bristol. When the Bristol was normally an HST you would often catch it around Maidenhead, now it’s normally an IET you usually catch it whilst it is still stopped at Slough. Hopefully at some point soon all the xx:50 departures will be IETs also, and so will be able to clear the line more quickly with their superior acceleration and top speed.
And it might also help when the Bedwyn services go over to IETs (as IIRC they are normally followed by a Heathrow Express from Paddington to give space before the following High Speed catches up). Removes another Turbo from the mains
Is the extension to the turnback siding at Bedwyn complete yet? Presumably this and any platform modifications are the only thing that prevents Bedwyn services using IET's now (subject to availability of stock)? While getting the wires going to Newbury is jolly nice, surely it's not essential? Or have I missed something obvious?The Bedwyn turbo goes at xx:18, and runs fast to Reading. The Oxford and beyond, normally HST or IET, then leaves at xx:22 (but stops at Slough). But because of the superior acceleration and top speed it catches the Bedwyn somewhere around Airport Junction and arrives at Slough a minute or two late. The xx:25 then goes to Heathrow, and shouldn’t be held up. But then the xx:30 Bristol goes, and will often see some yellow signals around Hanwell and Southall whilst the Heathrow train slows down for the junction to the airport. If not it catches up with the (by now 2 minutes late) Oxford and beyond train around Slough. It then follows it all the way to Didcot East, and invariably gets held at Moreton Cutting whilst the down Oxford waits to cross the up main.
Oh for a flying junction at Didcot East and no more Turbos on the mains!
The point is that much of it should have been completed, and management of the transition has been totally lacking.Wow, that article makes it sound like every project on the GWML has been completed and running for a couple of years. It seems to ignore that the vast majority are still ongoing and will be for some time!
- Electrification work still ongoing (some parts 'on hold')
- Engineering projects such as Oxford Re-signalling have only just been completed
- Hitachi have yet to deliver all the units to GWR
- Only a few of the 802 series as ordered by First are still to be delivered
- Cascade of rolling stock is still ongoing.
- Training is still ongoing, hampered by late delivery of stock and late running electrification
- etc etc!
In a land far far away....The point is that much of it should have been completed, and management of the transition has been totally lacking.
Anyone seen “Hapless Hopwood”?
I notice no one commented yesterday when there were no shortformed IET’s and today there are only two and that was caused by the points run through at Cardiff and a 10 car being dumped in Stoke Gifford whilst the chaos was sorted out, leaving Swansea 2 5 cars short.
Christ, that train is usually busy as a 5 (though regularly only 3 turn up) - reminds me when a train broke down at Stapleton Road a couple of years ago and blocked everything, and a 150 started from Bristol to run the service. It was completely overloaded at Bath and someone actually fell and got trampled by others trying to cram on. GWR ended up sending people to stations, even as far as Salisbury and Southampton in taxis. Obviously there had been no trains for an hour and a half at this point and they were advertising the local bus to Salisbury for rail passengers, which was already packed.There did seem to be some issues with the Bristol peak this evening, the low point being 1F27 1630 Cardiff-Portsmouth being formed by 150202 on its own, rather than the booked 5-car formation (unless by some magic it was strengthened at Bristol TM after I left the office.)
A fair few angry commuters on Twitter this morning, pointing out that due to the limited/no trains to Bristol Parkway, the Bristol Temple Meads DMUs are extremely busy this morning. Unfortunately the 07:30 Cardiff to Portsmouth is formed of 3 coaches vice 5 with many passengers being unable to board. GWR replying with due to more trains than usual requiring maintenance at the same time.
Shame it wasn’t possible to run a 5 car 80x between Cardiff and Bristol with a 158 taking over duties after.
I’m on the 06:00 Portsmouth to Cardiff train that’s running about 25-30 mins late due to a points failure north of Trowbridge and is 3 coaches vice 5, though no mention on Journey Check.
Agreed these should be London 9 coach trains.I'll put a counter point of view, where GWR had planned well. On Friday night Gloucester were at home to Bristol and for the last train to Swindon, which is the only train one can catch, not only did they get a 3 coach train, often 2, they lay on coaches to Stroud & Stonehouse departing earlier than the train to alleviate the expected crush on the train. It was a pleasant treat to get a seat the whole way home
On the proposed plan that GWR put out a few years ago I think the late night trains are still to Swindon & change there for Paddington. Suspect if it's a London train it would be a 5 coach trainAgreed these should be London 9 coach trains.
Usually an HSS calls at Severn Tunnel Jn to allow passengers to travel to Bristol Parkway and change there for Temple Meads but at the moment there is no alternative.
