Help- Being Prosecuted by TFL
J4u4u2c
19 Dec 2019
Even though its a bylaw offence will it show up on my DBS check, and some people say it mistakenly sometime appears if it appears can i call DBS and get it removed as its a bylaw and a non recordable criminal record.
I have worked so hard in my career to get to where i am, i made a stupid mistake of doing what i have done now I dont want that to affect my career etc.
J4u4u2c
19 Dec 2019
What information do you have suggesting such a minor conviction might affect your career?
The organisation I work for have public service clients- who do a full DBS check, if anything even remotely appears here I will be not allowed to work anymore thus getting my contract terminated.
However- I am wondering as they charged me for "Contrary to ByLaw 17(1) of the TFL railway byelaws made under paragraph 26 of schedule 11 to the greater london authority act 1999 and confirmed under sec 67 of the transport act 1962" this shouldnt appear on my basic/ enhanced DBS check right and only will appear on the PNC?
I spoke to the TFL's prosecutor and they said they will take this forward to court as they seen a regular pattern on my travel history pls help. I need to give my plea in my tomorrow online.
some bloke
12 Feb 2017
some bloke
12 Feb 2017
It shouldn't appear on the PNC (unless someone is convicted for a recordable offence at the same time) - that's what is meant by "non-recordable".
Please clarify exactly what the documents say.
J4u4u2c
19 Dec 2019
This may also be of interest:
https://www.gov.uk/report-problem-criminal-record-certificate/dispute-a-mistake
For enhanced checks, the police decide what information is relevant to the situation. But it isn't clear why they would decide - even if they knew about it outside the PNC system - that a conviction for this would be relevant.
https://www.gov.uk/dbs-check-applicant-criminal-record
Even though it is a non recordable criminal record I hear it can mistakenly be added to DBS/ Enhanced DBS in that case can I dispute?
Thanks for your help
J4u4u2c
19 Dec 2019
Or if that would be too much information, the gist of the rule(s).
My Contract states the following:
Security Clearance
During your employment you may be required to give your consent for security checks to be carried out. When this is required, you will be notified in advance and the purpose of the checks will be explained to you. Failure to provide consent in these circumstances may lead to disciplinary action and/or you not being permitted to work on certain client accounts.
some bloke
12 Feb 2017
Security Clearance
You won't fail to provide consent (I hope). Security checks aren't about making sure people are saints who never make an error.
Yes - see the links above on Subject Access Request and on disputes (if the latter isn't the right place they should be able to direct you).
island
30 Dec 2010
There is no such thing as a “full DBS check”, only basic, standard, and enhanced.
A conviction under the byelaws you’re being charged under should not appear on a basic or standard DBS check. It might (or might not) appear on an enhanced DBS check, if the officer handling the check request considers it relevant to the purpose of the check.
Who told you that “if anything even remotely appears here” you “will not be allowed to work anymore”? This is rarely if ever the case.
some bloke
12 Feb 2017
My Contract states the following: ...security checks...Failure to provide consent in these circumstances may lead to disciplinary action and/or you not being permitted to work on certain client accounts.
If the person won't give consent for checks, it's perfectly reasonable for organisations to have the option of disciplining them, or stopping them working on some projects.
That's very different from the idea that any minor conviction leads to dismissal. People often make mistakes at work. There is no obvious reason why a ticketing offence that doesn't imply dishonesty should have a significant effect on suitability for a job, any more than a minor mistake at work.
There are comments in a previous thread:
https://www.railforums.co.uk/threads/help-with-sv-application.195689/#post-4304861
Also, it isn't clear to me that the officer in a particular force would necessarily know about the "non-recordable" conviction in the first place.
https://www.gov.uk/government/publi...mation-are-shown-on-enhanced-dbs-certificates
J4u4u2c
19 Dec 2019
I have now recieved an outcome from the court, does this mean I have a criminal record? What is the severity of this? I made a good plea and gave all the reasoning and mitigating circumstances as to why i shouldnt get prosecuted, I am also dyslexic, dyspraxic and suffer from visual stress which i believed helped me with this case.
What is an absolute discharge and what are the ramification of this?
island
30 Dec 2010
An absolute discharge means that you were deemed to be guilty of the offence, but that the court thinks punishing you would not be appropriate.
You have received a criminal conviction. It is spent immediately so need not be disclosed for most purposes; however, if applying for certain professional roles, security industry, working with children etc. you would still need to disclose it.
BC
Guest
4 Feb 2019
Security Clearance
I hold an SC and DV clearance. A bylaws conviction like that will only ever be an issue if you fail to disclose it when asked. You'd be quite surprised at the convictions that are acceptable and they don't really care about - this is so far under the radar they wont care, UNLESS you fail to declare when asked.
J4u4u2c
19 Dec 2019
I thought I wouldnt have to declare my conviction because its spent immediately? So if a SC or DC is carried out do I have to declare it? If yes, what do I declare this conviction as?
BC
Guest
4 Feb 2019
You tell them it was a railway bylaws offence for being ticketless in a compulsory area and you had an absolute discharge. DON'T mention the costs, that will make it look like a fine and will possibly confuse them.
some bloke
12 Feb 2017
As others have said, this conviction is likely to be regarded as a very minor matter and you would be well advised to err on the side of disclosure if you are unsure.
You would be required to disclose the spent conviction for formal government "security clearance". That means an official Counter-Terrorist Check, Security Check or Developed Vetting. But the text you posted doesn't make clear that it's any of those.
Your organisation may be referring to some other check, notably the "Baseline Personnel Security Standard", which would be a normal standard to apply. The BPSS is not formal security clearance, and would not require you to disclose the spent conviction - see page 12 of the PDF document here:
https://www.gov.uk/government/publications/government-baseline-personnel-security-standard
Also, as a DBS check required for BPSS would only be the "basic" check, it should normally only show "recordable" convictions and so not include a byelaw conviction (see pages 21-2 of the same document, and the posts above).
3rd rail land
30 Jan 2019
Where the 3rd rail powers the trains
I hold SC with the Government as I work for a company doing work on their behalf. I can't remember exactly what you have to declare but this type of minor offence will not stop you getting SC.
It may affect your ability to gain DV though. I may have to gain DV myself and was asked some pre-vet questions by a security person. One of the questions was if I had any criminal convictions. There was no mention iof whetehre taht included spent convictions.
Islineclear3_1
24 Apr 2014
PTSO or platform depending on the weather
And your employer might not mind/care about the minor transgression itself; what does matter (to them) is that you are up-front and honest and declare it.
I have plenty of staff with minor transgressions and unspent convinctions (from many, many years ago) on their work records and they are still in employment
Well done, pay the £225 promptly and don't do it again
J4u4u2c
19 Dec 2019
Yes but my record is spent- so i dont have to let my employers know right?
Also- when they do SC and DV clearance will i have to declare it if its for public sector clients?
Generally speaking, no you wouldn't have to tell anyone as it's a spent conviction and (again generally speaking) there would be no obligation to disclose it. However you would need to look at your specific employment contract.
And after how long will this not appear on my Enhanced Dbs/ SC / DV check?
It will be recorded on the PNC indefinitely and will be revealed if the Police Commissioner believes that it is relevant to the enquiry being made.
duffield
31 Jul 2013
East Midlands
As far as SC goes, all I had to do (before I retired) from the Criminal Record point of view was provide a 'Disclosure Scotland' certificate (I was based in England, seems a bit odd to do it via Scotland, but it's just how it worked), which wouldn't have shown this sort of thing. But I understand DV and DV enhanced is more intensive.
As an aside, I was quite put out that despite me being totally upfront about having diagnosed depression and anxiety, which my employers were fully aware of, my SC clearance was delayed by six months despite me giving immediate and full permission for my employer to get all necessary information from my doctor. If I hadn't mentioned it, I'd probably have been fine. Anyhow, I'm retired now so 'whatever'.
BC
Guest
4 Feb 2019
You won't have to tell your employer as it is spent.
When they do either SC, a CTC or DV clearance you MUST tell them. You cannot consider any conviction as spent for these checks.
I appreciate you are worried but it simply wont matter one jot if you tell them. I know personally of people with convictions for using class A drugs that sailed through an SC check. Accidentally picking up the wrong ticket is not dishonest. Hiding it by not declaring it is way worse.
Llanigraham
23 Mar 2013
Powys
That depends on how the question is phased by the employer.
