Help with a problem
Discussion in 'Modelling, Simulations & Games' started by trainmananthon, 9 May 2015.
Thread Status:
  1. trainmananthon
    trainmananthon Member
    247
    4 Jan 2011
    Nelson
    Hi all,
    Don't know if you can help me on this one but my TS2015 seems to have developed a fault where it is impossible to drive some of the stock (Sprinters/Turbostars/375/456). The controls move inside the cab but nothing happens and using the HUD and keyboard don't seem to have any effect either, and also the headlights seems to be stuck on throughout a unit, such as the front, middle if there's more than one unit, and rear.
    I can provide a picture and possible video if needed.
    Thanks in advance
    Anthony
    Rail Forums
  3. duffers2324
    duffers2324 Member
    71
    1 May 2014
    Have you tried pressing E to move the little key into the lock bit in the cab as this releases the reverser and then press the DRA button so that it is off, then you should be able to set off, I also had this problem but doing this solved it.
  4. trainmananthon
    247
    4 Jan 2011
    Nelson
    Ironically the key is one of the only things that work. The controls are moveable, but they don't do anything if that makes sense. The throttle, brakes, reverser and headlights all move in the cab but have no effect, but the HUD and keyboard don't work whatsoever.
  5. deltic1989
    deltic1989 Established Member
    1,458
    21 Sep 2010
    If you haven't already, you could try verifying your game cache.
    To do this. Go to your Steam Library, and right click on TS 15, click properties, then the local files tab, and you will see the option to Verify the integrity of the game cache.
    This usually solves most issues.
  6. trainmananthon
    247
    4 Jan 2011
    Nelson
    I've tried that already, but for some reason to no avail. Thanks for trying to help though :D
  7. Darandio
    Darandio Established Member
    5,704
    24 Feb 2007
    Have you got a controller, or even raildriver connected by any chance?
  8. GB
    GB Established Member
    5,011
    16 Nov 2008
    Somewhere
    deleted
  9. trainmananthon
    247
    4 Jan 2011
    Nelson
    I do have a raildriver but it has not been used for years, and I've checked the game settings and it is definitely set to keyboard
    Also worth noting aswell that I've noticed the pantographs on some trains won't raise and have a permanent spark stuck on them
  10. Crossover
    Crossover Established Member
    7,163
    4 Jun 2009
    The other one was to clear the Blueprint Cache - not had to do it myself for a while - is it something that it's still possible to do?
  11. SpacePhoenix
    SpacePhoenix Established Member
    5,492
    18 Mar 2014
    Had you uninstalled any DLCs around the time that the problem started?
  12. duffers2324
    duffers2324 Member
    71
    1 May 2014
    Does anyone know the best way to get rid of the unknown error problem on TS I am doing a trainspotting scenario on the Edinburgh-Glasgow route at Waverley and I am getting the annoying unknown error on some trains and it is causing other trains to fail...Any help would be greatly appreciated.
  13. trainmananthon
    247
    4 Jan 2011
    Nelson
    Nope, haven't uninstalled anything
  14. Darandio
    5,704
    24 Feb 2007
  15. trainmananthon
    247
    4 Jan 2011
    Nelson
    Righto, cheers. I'll ask on there later.
    Actually, it doesn't matter now. I've managed to resolve the issue.
    Thanks to everyone for trying to help.
    Kind Regards
    Anthony
  16. Crossover
    7,163
    4 Jun 2009
    Any chance of advising how you sorted it? Every bit of collective knowledge helps!
  17. DasLunatic
    DasLunatic Member
    712
    11 May 2015
    Probably him forgetting to turn the DRA off...
  18. Crossover
    7,163
    4 Jun 2009
    Quite possibly
    It reminds me of when a family member of mine was playing on my copy of TS - they just tend to pull levers until the train moves one way or the other.
    In this instance, they picked to drive the Voyager, one of the more difficult ones get rolling, given that you have to key in, put the reverser to neutral, reset the AWS, reverser to forward, reset the AWS, DRA off then go!
  19. trainmananthon
    247
    4 Jan 2011
    Nelson
    Please elaborate on how you think the DRA prevents the reverser, brakes, AWS and lights from working...
    In response to Crossover's question, I found some mysterious files in some of the assets folders that prevented some trains from working. Said files were then swiftly deleted and now the trains work fine
Thread Status:
Share This Page
