Help with BOJ from Worcester -> Bristol -> Bath
Pumperkin
15 Jan 2019
Hi,
Looking for a bit of help in figuring out the best way of doing this:
2 adults (plus one under 5) going on 9th December from Worcester to Bath via Bristol. We want to jump off at Bristol to deposit bags in hotel, then go on to Bath for the day before returning to Bristol for the hotel.
I am then returning to Worcester on 10th September, and wife is returning on the 12th.
At present I am thinking 2 x off peak return Worcester -> Bristol then 2 x day return from Bristol -> Bath.
Not too worried about timings - going to Bath for Christmas market so would like to arrive by early afternoon.
Does anyone have any better ideas for the journey? Wondered if I can buy Worcester -> Bath returns and break journey at Bristol?
Pumperkin
15 Jan 2019
Yes, it does.
Wow thanks - £30.50 for the return sounds like amazing value.
Taking this to absurdities, if you had a return from Wick to Penzance, could you break journey several times along the way? Seems like a cheeky way of doing an all lines rover?
JB_B
27 Dec 2013
Note that ticket doesn't allow you to travel via Birmingham (but you could take the scenic route via Hereford and Newport if you like as well as the direct/fastest route via Cheltenham.)
Yes, you could. Obviously that's not as flexible as a rover but if I was planning a long distance tour around the country I'd probably use BoJ on a similar ticket as a spine for my trip; I think that might work out better value than a true rover.
There are some people in the rail industry who would like to remove this freedom.
tom73
24 Apr 2018
2 singles cheaper than a return. Much cheaper north to south than south to north.
(Sorry for image size. Unintentional)
JB_B
27 Dec 2013
(£88.35 -v- £166.50)View attachment 70577
Even if two singles are cheaper*, an off-peak/super off-peak return has the advantage that you can break your journey as often as you want during the whole (month-long) validity of the return portion.
* For example, a super-off peak return (route: + LONDON) with 16-25 railcard is £176.70 or it's £170.30 for an off-peak return route: Any Permitted.(I don't know which return time/date you'd specified nor which railcard.)
Great thanks :) So I shouldn't encounter any problems when trying to leave Bristol gate-line (shouldn't, not won't ;) )?
No indeed you may well find that the ticket just works both out and back in on the outward journey.
SickyNicky
Verified Rep - FastJP
8 Sep 2010
Ledbury
Worcester to Bath is also valid via Cheltenham, Stroud and Swindon, which might be an interesting way of going. On that route, the first class ticket looks to be quite good value, especially when Worcestershire Parkway finally opens.
Pumperkin
15 Jan 2019
I've tried to find the first class ticket but just keeps defaulting to standard class price. Either the prices are the same or there is no first class (I thought there was on GWR trains?). It's our anniversary so if I can 1st class for a nominal fee I'll consider it :)
No first class on the local trains. Probably not worth first class on either the ten minute journey between Bristol and Bath or changing to Cross Country at Cheltenham for Bristol. You could try selecting avoid Gloucester to force a Cross Country train between Cheltenham and Bristol.
