Help with print at home ticket not in my name
Jrhjrhjrh
25 Apr 2016
Hi sorry if this has been asked before, please point me in the right direction if so.
I've been given tickets by a friend but they have their name on and it says they require ID. Will I be OK to use them or will I get checked and kicked off the train or something?
I think I've attached a screenshot of the ticket
trentside
Fares Advisor
14 Aug 2010
The back cab
The ticket actually states on the ticket that it is for the named passenger only.
These tickets are not transferable, so without supporting ID at the minimum you'd have to pay again.
Indeed, you cannot use this ticket, it is only for the person whose name is printed on it.
Deliberate use of this could even be considered fraud (subject to prosecution under RoRA); unless you can get the name changed (I'm pretty sure you can't) you should not attempt to use it.
Jrhjrhjrh
25 Apr 2016
So I'm correct in assuming that
A. I'd probably be asked for ID
B. They can't be changed to my name
I guess I could ask Sam to lend me his bank card, but is that risky?
Thanks for your help
It would be deliberate fraud, as tickets[1] are not transferable. And now the ticket is visible on the Internet and the name is mentioned, there's a chance a TOC prosecutor could read it and have someone looking out for you on that train.
You should not attempt to use it.
[1] Even normal ones, but unlike with normal ones this type are properly enforceable.
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
Thank your friend and return the tickets to them. Then buy a ticket for yourself. You risk getting involved in a lot of hassle and a lot more expense if you try and use this ticket. You could conceivably lay yourself open to a being charged with fraud, as Neil says.
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
You're welcome, I wouldn't want anyone to get themselves into what may be deep trouble.
Jrhjrhjrh
25 Apr 2016
Thankfully I've not yet made any other plans relating to this trip, so nothing lost
MarlowDonkey
4 Apr 2013
Presumably a conventional ticket, which doesn't name a traveller is the same price. Apart from the possible convenience, what then is the advantage of a "print at home" ticket?
trentside
Fares Advisor
14 Aug 2010
The back cab
They are offered as a different fulfilment option on advance bookings with certain TOCs. The main advantage would be for those who live close to a station with no collection facilities, as it saves postage costs or having to make a journey to a station with facilities.
I don't think they can be amended anywhere but with the original purchase point, however.
Romilly
5 Nov 2013
Personally, I would say that convenience is the only advantage. Generally, I book ahead and collect my tickets from a TVM well ahead of the date of travel. But for late/short-notice bookings, the convenience of print at home can be a real advantage, especially when not knowing whether there will be time to buy/collect a ticket at the station before one's train leaves (will the bus to the station be late, will there be a queue at the TVM, will the TVM be out of order, etc?).
ricoblade
28 Sep 2015
One advantage is that you know you've got the ticket in your hand, mitigating any collection problems at the TVM and also not having to rely on the post.
5 Feb 2016
Saves costs for the company or the customer? I thought if you booked a ticket online starting at a station with no vending machine then postage was free. Of course, that assumes that the correct number of tickets will actually go into the envelope; as I've found out recently with VTEC this is not always the case!
MarlowDonkey
4 Apr 2013
Whether the postage is free depends on which website you purchased it from. If possible you would book from one of the TOCs that delivers for free, but that's not possible if you are taking up a special offer.
bb21
4 Feb 2010
Both really, but as with all things, not always the most cost effective or convenient option for everyone.
There is a cost for some people to go to a station and pick up a ticket, and obviously convenience can have its price too, but if you are not fussed about having to collect the ticket from a TVM and keep it safe, then [email protected] may not be for you.
