Help!
devon_metro
11 Oct 2005
Help!I have just downloaded and installed the GWML2 route from UKTS although it is not showing up when i go to load a route in MSTS! Any help on how to sort this??
(I installed into program files/microsoft games/routes/gwml2 where it should be)
Any help would be greatly appreciated!
Thanks
Max
8 Jun 2005
Cardiff
I don't know the route at all, but failing to run the .bat file sometimes causes that error.
Muppet
7 Aug 2005
In a Box
Hi.
This should sort any problems with GWML
1) Rename GWML2 to GWML
2) Make Sure you have X track or Finescale installed, this will sort out the Track Database.
3) Magnetic Platforms 1 2 3 most be installed for this route. then it should run as normal
Just in case anything goes wrong im not responsible for anything that goes wrong with your computer
devon_metro
11 Oct 2005
Also you need to save GWML2 as GWML without the 2 on the end
so program files\microsoft games\train sim\gwml
