Holmes Chapel [HCH] to Manchester Airport [MIA] via Manchester Piccadilly [MAN]
totalmus
29 Jun 2012
Hi All,
I do a daily journey normally Manchester Airport to Holmes Chapel return.
On occasion, I return to either Heaton Chapel or Manchester Piccadilly, rather than the airport.
Previously, I've always been told a £9.60 returned covered this journey, as it allowed you to catch a direct train back to the airport, or go on the Stockport line and change at Manchester (and exit the journey early). This ticket has now changed to read Route: Direct, when previously it was any permitted. There is now an any permitted route at £13.
Has something been introduced to stop abuse of this ticket (as it is a cheaper way to get to Manchester from Holmes Chapel)? Can I still use the £9.60 for this journey - or do I need to buy the more expensive any permitted?
If so, I assume there is nothing stopping me getting on at the airport but buying a ticket from East Didsbury to Holmes Chapel return - this is only £10.20 and allows travel by any permitted route, so I assume this would allow a return journey via the Stockport line, and completing the journey before the airport.
Any help appreciated - the advice from guards seem to be contradictory!
Thanks.
bb21
Emeritus Moderator
4 Feb 2010
Holmes Chapel is associated with Crewe and Wilmslow Group.
Manchester Airport is a member of Wilmslow Group.
Your origin and destination share a common routeing point - Wilmslow Group - therefore the only permitted routes are either on direct trains or following the shortest route (or those no more than 3 miles longer).
Shortest Route Calculation
[Table 84] Holmes Chapel - Wilmslow: 10.5 miles
[Table 84] Wilmslow - Manchester Airport: 4.25 miles
Total: 14.75 miles
[Table 84] Holmes Chapel - Manchester Piccadilly via Stockport: 22.5 miles
[Table 85] Manchester Piccadilly - Manchester Airport: 9.75 miles
Total: 32.25 miles
You are not permitted to travel via Manchester Piccadilly on a Holmes Chapel - Manchester Airport Route Any Permitted ticket. It would seem that you have been misinformed and undercharged previously when you travelled via Manchester Piccadilly (or Heaton Chapel).
On the same note, East Didsbury is associated with Manchester Group and Wilmslow Group. It shares a common routeing point with Holmes Chapel, ie. Wilmslow Group. The only permitted routes are either on direct trains or following the shortest route (or those no more than 3 miles longer). You are not permitted to travel via Manchester Piccadilly (or Heaton Chapel).
totalmus
29 Jun 2012
Actually one more query - Heaton Chapel falls under the Stockport routing group (and therefore there is no common routing group).
Could you get a return Heaton Chapel to Holmes Chapel (and then travel Manchester Airport to Holmes Chapel, and Holmes Chapel to Heaton Chapel?
totalmus
29 Jun 2012
Thanks for the suggestion - the outbound journey is before 09.30 - unless I've had a very good lie in!
bb21
Emeritus Moderator
4 Feb 2010
Heaton Chapel is associated with Manchester Group and Stockport.
Fares Check
Holmes Chapel - Heaton Chapel Route Any Permitted Anytime Day Return: £8.70
Holmes Chapel - Manchester Stns Route Any Permitted Anytime Day Return: £9.90
Holmes Chapel - Stockport Route Any Permitted Anytime Day Return: £7.40
Stockport is an appropriate routeing point for Heaton Chapel.
Crewe - Heaton Chapel Route Any Permitted Anytime Day Return: £11.10
Wilmslow - Heaton Chapel Route Any Permitted Anytime Day Return: £4.10
Wilmslow Group is an appropriate routeing point for Holmes Chapel.
Wilmslow Group to Stockport is permitted on map MH, which means you can either travel direct between them, or go via Manchester Group. This permits you to travel Holmes Chapel - Wilmslow - Manchester Airport - Manchester Piccadilly - Heaton Chapel, or Holmes Chapel - Wilmslow - Stockport - Heaton Chapel.
This is in addition to direct trains between Holmes Chapel and Heaton Chapel, and the shortest route.
I think your suggestion would work. There is no break of journey restriction on any ticket, which means you can start short at Manchester Airport.
Heaton Chapel - Holmes Chapel
Route Any Permitted
Anytime Day Return
£10.20
or
Off-Peak Day Return
£8.90 Restriction B1
