Hot Box Detectors
Coxster
9 Jun 2005
Myself and Seth had a little discussion about hot-box detectors. Do they work on some sort of infa-red system, simular to that used by Police/Search & Rescue helicopters?
Simming
8 Jun 2005
Cornwall
they scan the tempretures, and if there is a large difference in the tempretures on each axle, there will be an alarm sounded, and the signal in advance will be returned to on. They do detect infra red radiated from the hot axle.
Simming
8 Jun 2005
Cornwall
The Modern Signalling Handbook also quotes that signalmen could ignore the alarm if it was trigged by the heritage DMU stock.
Coxster
9 Jun 2005
I got wondering after Alistair (a few guys know him from here) was showing me how hot 'Richborough Castle' was.
Simming
8 Jun 2005
Cornwall
I dont quite think you know what a hot box is 1288.
they are positioned next to the rails, on the outside.
Met Driver
8 Jun 2005
The detectors are, yes.
gaje - A Hot Box is an overheated axle journal or bearing caused by poor lubrication, admission of sand or grit etc., or overtight fit of axle ends.
TheSlash
7 Jun 2005
Marwell Zoo
I think he's right Simming, the 225 sets have inbuilt monitoring systems.
Hot boxes are a nightmare, you need to dump at the very nearest location, not the most convient, so places like goods yards that haven't been used for 30 years. Then you need to go and fit a wheel skate {a craddle to move the siezed axle}, then you need to skate it to the nearest lifting depot {Eastleigh, Bournemouth, Wimbledon, Brighton etc}, 5mph across points and crossings, 25mph on plain line
