pdq
- Joined
- 7 Oct 2010
- Messages
- 803
The 185 I was on last night was verging on the chilly, especially where I was sat, near the ceiling fan. The lady next to me had wrapped herself up in a cardigan.
185s seem to have decent aircon, although it come down to personal preference about which temperature it should be.
I do think it is quite silly that some of the newer rolling stock do not have temperature controls, and have to be set at the depot by a fitter. Everyone knows that the UK weather is changeable, and can be cold in the morning, but hot during the day.
While on the subject of air conditioning, I am going to ask a question that has been puzzling me for a while.
How do they switch it off when the trains are stabled at a depot at night? I've seen pictures of guard's vans with a button to turn off the lights, but never an A/C switch off button. Do they just shut down the trains engines or lower the pantograph or do they have to go to each carriage individually?
If the air conditioning was set to keep the carriage temperature at 21 degrees for example, there wouldn't be a problem. With a system like that, if it is cold inside the carriage, the heating would be activated (either electric or heat pump- do any trains use heat pumps for heating?). If it is slightly warm, the ventilation fans would be activated to provide fresh air from the outside without wasting energy running the compressors ect. If it is hot inside the carriage, the air conditioning would be activated.
The systems are probably designed like this (can anyone confirm this?). The only problem is when the system is faulty, so the heating or air conditioning runs constantly. Instead of only being able to alter the temperature at the depot, they should have the following controls:
Mode
Off
Auto
Heat only
Cool only
Temperature
16-26 degrees C in 1 degree steps
Constant on (only working if the mode is heat or cool only)
If the above system was used and was able to be adjusted from inside each carriage individually (by the train crew from a locked panel in the vestibule, there wouldn't be any problems.
Are there any trains with a system like this? What controls do the A/C systems have that can only be operated at the depot?
The problem is most guards can't be bothered to, or are afraid to tinker with the simple buttons.
At this time of year TOCs start switching the heating off when the units are in for service. Part of the problem at the moment is that the weather is so changeable that even the past 2 days it has been fairly cold first thing in he morning and then scorching hot later so they can't win either way.
Well maybe if whatever idiot designed the trains hadn't been so stupid as to not put any means of controlling the heating system other than at a depot they would be able to win. What a ludicrous situation.
Mode
Off
Auto
Heat only
Cool only
Temperature
that is rather harsh and I don't know where you get your facts from that they can't be bothered. I don't sign 170s but I sign and have signed a handful of EMUs including 377s and have absolutely no idea how to alter the air con or heating apart from tripping the heating mcb's located in each coach and my traction knowledge is fairly strong. If there is a way we are not trained in it for what ever reason. Tripping the mcbs can be done but is a real last resort as mcbs are not there to be treated like switches, they are more like fuses and tripping he heating out via them is similar to switching off your TV at home by tripping the downstairs plug socket fuse on the main fuse board very time.
Quite simply we have no control over the settings of the heating/air con on trains, it is all done in the depot as there are no control panels for it within the train, mostly it is in thermal units located under the carriages and not accessible to us.
Indeed but we are talking about trains designed in the 70s and 80s with less technology.
The only time Traincrew can open a window on a class 378 is when the air con has packed up, the passengers are complaining, control have said its ok and Bombardier have said its ok, then and only then can the traincrew can do something.
On the flipside of this i was working a train today where the passengers got lovely cold air con and the traincrew were left cooking as the thermostat in the cabs were not working so all the traincrew were getting was warm and very warm air! Suffice to say i spent most of my time inside the train to keep cool.
I was told by the twitter team that the driver has no control over the thermostat or heating and it can only be corrected by the fleet team in the depot.
Last Summer, in the morning as we were getting off the train, the cleaners would go through the carriages closing all the windows before the train went to the sidings. I'm sure they sat there all day with the windows closed and heating on.
It didn't look absolutely impossible for a guard to be trained in such a task.
Mode
Off
Auto
Heat only
Cool only
Temperature
