As opposed other forms of transport ?
Greta Thunberg could inspire a rail resurgence!
We estimate that while a flight from Edinburgh to London emits 177kg CO2 per passenger, and existing trains (‘HSTs’) emit 34kg per passenger, that an Azuma will emit only 28kg — 84% less than a flight.
Teenage activist Greta Thunberg has said she hopes to join Extinction Rebellion protests as she sets off for London. The 16-year-old founder of school strike for climate, from Sweden, will be travelling to the UK by train, in a bid to reduce her carbon footprint. She tweeted alongside a photo of herself: ‘Now awaits two days of train travel. Next stop London!’
Read more: https://metro.co.uk/2019/04/20/gret...inction-rebellion-london-9276389/?ito=cbshare
Twitter: https://twitter.com/MetroUK | Facebook: https://www.facebook.com/MetroUK/
It also rather depends on how well used they are. I rather suspect that the Voyager carriage currently taking my wife and me (and presumably the driver) from Reading to Brum is using more fuel per occupant than my Citroen C1 would for the equivalent trip.
So after you've added all of the CO2 and pollutants of all NR's 'yellow trains' to the total UK rail environmental impact and see what the increased impact per passenger/tonne km is. I doubt that it makes a noticeable difference. The smoke from all of the the worst locos/DMUs is probably less than that emitted from every passenger aircraft or all the badly adjusted IC road vehicles. The picture is irrelevant to this thread.Very green....
Sorry to be pedantic, but the loss of energy in the wheels is nothing to do with friction.Well they can carry more people than buses or cars and even aeroplanes and can coast for miles. The low coefficient of friction of steel wheels on steel rails means less energy is required to move the same mass than with road transport.
Rolling resistance, sometimes called rolling friction or rolling drag, is the force resisting the motion when a body (such as a ball, tire, or wheel) rolls on a surface. It is mainly caused by non-elastic effects; that is, not all the energy needed for deformation (or movement) of the wheel, roadbed, etc. is recovered when the pressure is removed.
The figures quoted are per passenger so are probably the best comparison of the alternatives a passenger could choose between to do the same journey. However the detail gets very complicated.How many passengers on a plane compared to how many on the train ? How many in total per day for both ?
Well today is an exception for obvious reasons. Also as bad as a Voyager is, I'd take an empty one over a Citroen C1.It also rather depends on how well used they are. I rather suspect that the Voyager carriage currently taking my wife and me (and presumably the driver) from Reading to Brum is using more fuel per occupant than my Citroen C1 would for the equivalent trip.
That's 28 miles as the crow flies, must be at least 35 by rail. Impressive.I think the thing that has stuck with me about coasting at least is that it was apparently (possibly still is), possible to coast from Tring on the WCML the while way into Euston at 100mph if one shut-off at Tring.
Adjust your monitor, that's yellow.Very green....
It was done not that long ago during a power failure on the southern WCML - I can't remember the details just now but I think the driver managed something like Hemel Hempstead to Euston.I think the thing that has stuck with me about coasting at least is that it was apparently (possibly still is), possible to coast from Tring on the WCML the while way into Euston at 100mph if one shut-off at Tring.
No problem, common mistake including on a TV documentary I saw not so long ago.Well my knowledge was basic at best, most of it is snippets recalled from a BR training video called something like - "Steel wheel, steel rail".
It's not quite as simple as that though - as other have pointed out, trains can coast a lot more than buses/coaches so they'll be drawing power a lot less. Also, a bus will be drawing power for much longer (e.g. it's 9.5 hours from Glasgow to London by bus versus 4.5 by train).Despite greater rolling resistance, in most circumstances buses and coaches probably have less emissions than trains, mainly because their weight per passenger is less.
High utilisation electric trains are greener than bicycles. but low utilisation electric trains are not.
You can easily Coast from Radlett to St Pancras. St Albans is possible as well if you are early.
