Increasingly, with the latest signalling systems, “Resignalling” is becoming less popular. There are essentially three parts of the signalling system:
Control System
Interlocking
Ground equipment
These parts are joined by a transmission system (effectively a telecoms link).
New control systems now are, effectively, data run on something little different to a home computer.
New interlockings now are, effectively, data run on something little different to a home computer.
Ground equipment is broadly the same regardless of what the interlocking / control system is.
Each of these three components can be, and are, renewed independently depending on their condition / obsolescence.
The big cost in big resignalling schemes is all the design, data prep, testing, and so on, which uses very specialist skills (eg there’s only a couple of hungpdred signalling principles testers in the country). Testers in particular tend to get used at awkward times of the day / week / year - not many of them ever have a Christmas Day off for example, but my word they are compensated for that. Another big cost is all the cabling and cable routeing, however with modern IP based signalling the cabling this is reducing.
As @MarkyT says, big resignalling is often driven by major layout changes, and that means all the ground equipment needs to go whether it is life expired or not; often the same applies to the control equipment and interlocking, ie it is cheaper, easier and safer (see Waterloo) to build new than amend old.
So, in theory, headline major resignallings will reduce in number over the years as the relevant components are renewed when necessary, rather than doing the:all in one go.
Regarding mechincal / small boxes; they will, eventually, all go. I don’t have the numbers, but I reckon around 30-40% have gone in the last 10 years or so. Certainly in Anglia there have been nearly 40 small boxes closed in the last decade, including the Wherry Lines (some were just Level crossing gate boxes), and there’s now only about 30 left.
Control System
Interlocking
Ground equipment
