On a different thread people were suggesting it would take 7-12 minutes to change from diesel to electric and vice versa.Isnt there a way it could be done quickly?Cheers
Ryan
I don't actually remember the line speed at Bedford, but I'm pretty sure it's not 110mph...
Is there any reason why the changeover could not happen on the move?
There isn't. People making assumptions that Bombardier will use something similar to the management system on the Electrostars, which have to stop.
I don't think people were making assumptions, they were just commenting on what happens on some stock now.
Like you say, there is no reason why it can not be done. But there is no reason why it can't be done on Electrostars either if they had been specced properly.
I say this so often that it's almost become a catchphrase. You can't raise a pan on the move because you risk damaging the pan and/or the OLE, and possibly causing a dewirement.
O L Leigh
And what current bi-mode (D/EMU) stock are the comments being drawn from?
Class 373 has been doing it for years at up to 100mph. It has never caused a de-wirement and the pan-heads cope fine.
None in the UK for sure.
I apologise for a discussion taking place on a discussion forum. We will stick to facts from now on with theories and opinions no longer allowed :roll:.
You really seem to have a problem with discussion?
Nope, no problem with discussion. I just don't see how we can really quote numbers we don't have evidence to back up.
So like I said, you want facts or nothing at all - so I guess we can't talk about the project until is officially announced that 22X will have a pantograph coach inserted and the specs are released - because only then will there be any 'evidence'.
The simple answer is that, as there are no bi-mode trains, it is impossible to say how long a traction changeover would take and whether 7-12 minutes is a reasonable estimate or not. Such matters will be down to the design of the train itself and the operation of the train management system. At the present moment we're all just plucking numbers out of the air with nothing to base it on.
O L Leigh
You can talk about whatever you like. I don't want to drag the thread any further off topic. I just don't get where people are even getting these numbers, that's all.
Thank you!
Only on CTRL OLE though.
O L Leigh
O L Leigh
China has the pantograph technology to raise and lower the pan at speed
So do we... see above.
Good... so I don't see what everybody's getting so worked up about then. Changeover at line speed, without 8.... or 12 minutes delay!
If you were to read the posts, you would see that the time included linespeed to zero for a station and backup to linespeed. It seems most people are overlooking that fact because it suits them.
It seems to me that the only timing penalty issue here is whether you need to wait for engines to warm up or not, which you should not need to do if the train is designed properly!!
