How much? Crazy prices for 1st Class Stafford to Torquay!
Discussion in 'Fares Advice & Policy' started by Masboroughlad, 13 Sep 2017.
  1. Masboroughlad
    Masboroughlad Established Member
    1,313
    2 Mar 2011
    Midlands
    Hoping to go to Torquay from Stafford on 3rd October, direct at 0902.
    2 of us, Standard class just over £100 return.
    Thought we might splash out and check out first class. £1001!!!! I've got back on to my chair.
    How can that be justified? We are flying to Svalbard via Tromso, back to Oslo, on to Hamburg and back to the UK for less than that later this year.
    Needless to say, we will be going standard class!!!
  2. DarloRich
    DarloRich Veteran Member
    16,742
    Work - Fenny Stratford(MK) Home - Darlington
    split tickets?
  3. ainsworth74
    ainsworth74 Moderator Staff Member Moderator
    17,638
    Well considering that you're looking at a pair of 1st Anytime Returns I'm not sure what you expect? They were always going to expensive as they're priced for people on expenses. If your willing to indicate when you intend to return I'm sure someone will be able to offer advice.
  4. AlterEgo
    AlterEgo Established Member
    9,278
    I suspect these fares are deliberately ridiculous precisely to discourage heavy patronage - it's only a Voyager and there have been occasions in the summer when the whole carriage has been full on the Paignton/Torquay trains. There just isn't the capacity for people on walk up tickets.
  5. LNW-GW Joint
    LNW-GW Joint Established Member
    10,694
    Sky-high First Class fares on Cross Country go back to Arriva's decision when they took over from Virgin to mark up Anytime fares by 100% from Standard, instead of the usual 50%.
    As they have a monopoly on Birmingham-Bristol there's not a lot you can do to avoid it.
    If you buy separate 1st returns Stafford-Birmingham (£29.60), Birmingham-Bristol TM (£142.20*) and Bristol TM-Torquay (£105.40*) = £272, you can save a packet.
    The through Anytime fare (£500.50) is set by XC, while Stafford-Birmingham is LM and Bristol-Torquay is GWR, who don't have the same swingeing policy on First fares.
    *Note that the Birmingham-Bristol and Bristol-Torquay fares are Off Peak Returns (after 0930).
    You pay a fortune to start your journey before 0930.
    On the 1002 or later the XC through Off Peak fare is "only" £265.60.
    You might get a better deal with Advances if you know your times both ways.
    Somebody will also chip in to say you could go via London and get cheap 1st Advances on VT and GWR.
  6. oldsiggie
    oldsiggie Member
    453
    24 Sep 2014
    By way of comparison, as people say its cheaper to fly.... Birmingham to Newquay £2,000 return 1st Class.
  7. Merseysider
    Merseysider Established Member Fares Advisor
    3,816
    22 Jan 2014
    North West
    Birmingham to Bristol should be split at Cheltenham.
    Edited to add that if flexibility is needed, there is no need to pay for the 1st Off Peak or Anytime fares. XC offer advance fares until 10 minutes prior to departure which, following the same split pattern, will be even cheaper. Not always available on their busiest trains, but south of Birmingham you'll be fine.
  8. bb21
    bb21 Moderator Staff Member Moderator
    21,877
    4 Feb 2010
    120%
    varies but mostly 60%-70% AIUI
  9. dave87016
    dave87016 Member
    851
    9 Dec 2008
    Lancashire
    try Stafford to Newton Abbot direct or Standard class from Stafford to Birmingham NS and then 1st Class Birmingham - Newton Abbot there can generally be much cheaper fares
    I have looked 1117 from Birmingham is £125 for 2 adults 1st class advance single without a railcard discount is the cheapest I can find for that day if you can go later then 0902 from stafford
  10. gazthomas
    gazthomas Established Member
    1,680
    5 Jun 2011
    St. Albans
    If you don't have a railcard I would recommend a "Two Together" for a third-off.
  11. yorkie
    yorkie Administrator Staff Member Administrator
    35,815
    Trainsplit will sell you 1st class return tickets for £144.77 on the 0902 Stafford-Torquay and the 1013 Torquay-Stafford returning the next day.
    Through fares can be very costly, especially on XC, and in particular in 1st class.
  12. swills
    swills Member
    521
    15 Jan 2008
    Is this 'fare' not like the one plastered all over the press a while ago with the guy going by air to some Euro Capital and then to London saying it was cheaper than getting a train to London ?
  13. Deafdoggie
    Deafdoggie Member
    374
    29 Sep 2016
    I live in Stoke, and spent many summers working in Dawlish-going down Monday morning, returning Friday afternoon.
    Standard class was cheaper to split SOT-Stafford, Stafford-Birmingham, Birmingham-Cheltenham, Cheltenham-Bristol, and Bristol-Dawlish. Particularly because I was on the train before 09:30 too!
    Cheaper still, if time not too pressing, is to London, then to Torquay. Plus you'll get better, and more, food on Virgin.
    I do have sympathy with XC though. The train is full and standing with the fares they charge, if they made it cheaper, how full would it be?
  14. DarloRich
    16,742
    When I flew on that route I did not note a first class cabin on the Dash8
Share This Page
