The cab interiors are subtly different on all three classes. If you were in a Peak cab, you could tell whether it was a 44, 45 or 46 straight away. The Class 44s were all vacuum-only until withdrawal, so retain the chunky Davies and Metcalfe vacuum brake valve also used on Class 26s. Given the Crompton-Parkinson electrical equipment, the power controller and master switch are also the same as those on Class 26s. The big chunky power handle doesn’t look very user-friendly, but it’s perhaps easier to move than it looks.
All the extant Class 45s are dual braked (in fact I think almost the whole class had received dual brakes by the mid-70s) so they use the standard Davies and Metcalfe FV4 train brake valve as you’d see on a dual-braked 47. The electrical equipment is still Crompton-Parkinson, but the power controller and master switch are a more modern design (which looks much kinder to the driver’s hand), the same as those used on the Class 33.
A Class 46 would have the same Davies and Metcalfe brake controllers as a 45 or 47 (again, I think these were all dual braked in the late 60s/early 70s) but the master controller is again different- because Brush electrical equipment is used, the power controller and master switch are the same design as those used on a 31 or 47 and sit on the same pedestal as on those classes. Presumably the driving technique for a 46 is quite similar to that for a 47?
I‘m sure there are other subtle differences in the cabs too, but those are the ones I can think of. Obviously the secondman’s side of a 44 will be different as there’s no train heating equipment at all, and again on a 45/1 with controls for ETS instead of steam heating. 45/0s and 46s of course had controls for steam heating- presumably they all had Stone-Vapor boilers, or were some other kinds of boiler used in the 46s?
When new some at least of the 44s had slatted louvres over the bodyside vents rather than the grilles of the later models.
I get the impression these were later retrofitted with grilles
These were 44009 and 44010 (or D9 and D10 as built), and I think it was an experimental modification which never took off. As far as I can see from photos, they retained them until withdrawal in the late 70s.
