Philip Phlopp
- Joined
- 31 May 2015
- Messages
- 3,004
Okay, some good discussion! Thanks.
(1) correct, the trains might still run, but there was also a contract that forced TPE to run trains with first class to Blackpool which was ended for example. And Lincoln and Hull services were listed as 'Anglo Scottish' at the time.
(2) is much slower than HS2, I don't think it'll be unfair to compare it with a slow stopping Pacer to a 185 express, people will get the fast train. The funding on ECML makes the HS2 business case weaker, why build HS2 if current services will be suitably fast, and it won't take North to South passengers away from the current line? A major selling point is the York connection and if most trains fail to use it, what's the point?
(3) Aberdeen people would surely change if it's faster by HS2, if not the claim it will benefit Scotland alot is a bit of a joke since the ECML upgrade (a seperate scheme) is the only timesaver they have.
(4) the intermediate places that keep the WCML and ECML going are Birmingham, Manchester, Liverpool, Leeds, Newcastle and are all to be served by HS2 as the fastest connections.
(5) I'm confused about this, if 1 Train Per Hour from London to Edinburgh used HS2 instead of ECML, there won't be extra room for London to Newcastle as the track from York to Newcastle would be shared by the HS2 route, so no new capacity and why would a Newcastle person use the slower service? And HS2 using that section would likely diminish any possible HS3s capacity too.
You're making the classic mistake of working on current and indeed historical traffic demands, providing no possibility of growth.
1) TransPennine's first class service provision is neither here nor there, we're talking about journey options, not seating options. Train layout, seating, catering, length, station calls are always being adjusted based on demand, timetabling constraints, pathing constraints and financial considerations. It's just as likely more capacity will be provided as it is capacity will be removed or services dropped.
2) that's end to end traffic again, the ECML is still vital to connect stations that won't be served by HS2 services, so everything south of York on the ECML, with stations north, even those served by HS2. HS2 won't help me do an Aberdeen to Peterborough journey.
3) see above. If HS2 doesn't go to where they're wanting to go, they won't be changing, will they ?
4) only Leeds and Newcastle keep the ECML going ? That's news to me and I suspect everybody else in the industry.
5) seats on the route, not necessarily paths. If end to end traffic (Edinburgh to London) moves onto HS2, that leaves more seats available for people travelling from Edinburgh to somewhere on the ECML that HS2 won't serve.
