Am I right in thinking that the current plans have no HS2 station at Crewe; just some extra platforms at the classic Crewe station (round the back where the goods lines are) for trains joining the WCML?
Crewe could both have through tunnels and be connected into the existing station if the powers-that-be looked at a national connectedness strategy, rather than just business cases which inevitably prioritise London services at the expense of all the rest of the UK.
Im confused, that is what is happening at Crewe, junction to the south and tunnel underneath as part of 2B.
Antwerp is an amazing station but was a unique case where the original station was a terminus on a very constrained site, but the new line needed through platforms. There was clearly no room for additional platforms at ground level while the terminus layout made projecting such lines northwards impossible. I'm pleased they did what they did rather than routing high speed away from the city centre and I'm sure that plugging in so intimately to the city and it's local transport as it does provides a most useful service and hopefully a very successful result in terms of passenger numbers. In Crewe, keeping the station where it is, (whatever the extent of the rebuild) is the best result for local connectivity, to the town itself and to the wider rail network. In addition, there is plenty of rail land in the corridor for expanding the existing station site with additional through platforms. The high speed tunnels beneath such a complex need only carry non-stop traffic so do not require expensive platforms underground.
reminds me of Euston, St Pancras, etc... what costs we are taking for refusing to consider going deeper!a terminus on a very constrained site
but no platforms on the new through lines within the existing station footprint, unlike at Antwerp. The current station layout is pretty well full (and we are told that HS2 is intended to make more capacity - i.e. trains - available on the classic network) so I would have though that extra platforms would be needed to allow HS2 and the upgraded WCML services to all fit in.
HS2 platforms on the independent lines would have to either go over the culverted river like the current surface lines (and bulldoze the heritage centre) or burrow beneath it, meaning a new low-level station that would wipe out the independents.
The consultation asks for views on:
a. The vision for a hub station at Crewe, as recommended by Sir David Higgins in 2014, and set out in paragraphs 3.3 - 3.7
b. Providing 400m platforms at Crewe station in 2027 which could enable longer HS2 trains to and from London to split and join at Crewe, meaning other destinations, such as Stoke-on-Trent, could be served by a high speed service, as set out in paragraphs 5.8 - 5.18
c. Providing a junction north of Crewe station to connect the West Coast Main Line (WCML) and the high-speed line, in 2033 as part of HS2 Phase 2b. This could enable northbound high speed connectivity from Crewe, providing more seats between Crewe and London, as set out in paragraphs 5.19 - 5.28
d. Levels of future freight growth that should be considered in planning a Crewe Hub
e. Levels of growth in local and regional passenger services that should be considered in planning a Crewe Hub
f. The role the local area could play in realising a Crewe Hub, including by way of local funding contributions and evidence for potential levels of growth
There is a rather vague consultation on the DfT website:
https://www.gov.uk/government/consultations/crewe-hub-options-for-building-on-existing-connectivity
Item (c) would be integrated with the new site for the HS2 depot north of Crewe, and allows stopping trains to join HS2 northwards as well as south. Non-stop trains would still pass through the tunnels under the station at close to maximum speed - which will have to be very deep to pass under the Independent lines and the stream I believe is somewhere underneath them.
I hadn't twigged that it might just be the Cardiff services that would get new platform(s?) presumably on the existing Manchester Independent lines. That might be a good idea anyway if they were within a reasonable distance of the rest of the station.
To see the "stream" I suggest you walk a few hundred yards down Macon way from the station and look at it! After almost any amount of rain it floods all the valley upstream of Macon Way and after a flood I am always surprised that it hasn't destabilised the whole embankment under Crewe North Junction... now that would be a Lamington crisis multiplied many times!
Not sure some of the things you have highlighted are big enough problems to warrant massive infrastructure interventions, apart from the Wales Manchester services which is a problem regardless of HS2 turning up. New Independent line platforms won't simplify track or signalling either as you wouldn't remove any existing functionality in the existing station because of that.
The only real problem on the up side is that platform 5 is too short and the turn out at the London end is too slow, platform capacity isn't really an issue.
Down London Manchester trains (that don't get moved to HS2) will always use the main station and won't get shunted to any new Independent line platforms.
The rest is just overkill for eradicating conflicts, going into the bays, on either side, once an hour isn't stopping the job.
I think that we should be looking at Antwerp-type solutions to fitting modern high-speed lines and extra platforms into Victorian Infrastructure. What the Belgians did there is brilliant, and it's a pity it wasn't copied at St Pancras.
There's no need for that at Crewe as there is plenty of unused land to put extra platforms on.
By contrast it would be something that would be good (albeit too expensive) at Birmingham, having a New St Low Level instead of having a separate Curzon St.
Would you keep Birmingham Interchange if that was the case? Or would you be proposing removing the Birmingham spur and making it the main line and effectively being in tunnel from around Solihull to the other side of Wolverhampton?
What would be ideal would be for any northbound connection to be designed such that captive gauge trains could use it in future. It doesn't necessarily need to be fully segregated, and if there aren't any major tunnels or bridges (both under- and over-bridges, given gauge constraints) it might not be that difficult to clear a GC gauge. That would give maximum flexibility for the future.
Yes, I like the additional suggestion of removing the fast lines as they would be superfluous. Doing so would mean that the slow turnout out of platform 5 could be completely eliminated. However, because of the nature of the roof pillars I think you'd be unable to move the central part of the platforms themselves, although they could be gently curved from the point the roof pillars stop.
I don't think the basic station layout can be rearranged much through its core without demolishing the whole lot which I presume is listed. The LNWR built everything on the cheap and there are spindly pillars holding up random bits of roof everywhere.
