- Joined
- 14 Jul 2011
- Messages
- 16,710
Well we could go for a Chuo Shinkansen type solution - since the technology is now ready for economic application.Why would you need to go up to 300mph? Can you actually find an alignment that could work at that speed - minimum track radius is proportional to the square of the linespeed. You would need novel braking technology and significant groundworks to avoid hitting critical velocity in the underlying soil. Power requirements would be significantly higher. And what time advantage would this actually give, considering most of the time would be taken in accelerating and braking? I can see it working in, say, China but the UK doesn't need to go this fast.
And the acceleration rates that Maglevs are capable of are absolutely absurd because the traction power supply is in the track and not the vehicle.
Commuting from London to Edinburgh - would certainly kill of regional nationalism if nothing else.
Because to give these minor destinations minor benefits, we hamstring the ability of the line to benefit major population centres.Why would you want to stop destinations off the high speed line benefitting from it? As it stands trains to and from the North and Scotland will benefit from HS1 as soon as the first section opens.
Lets imagine that HS2 was being built as a self contained Shinkansen using Breitspurbahn gauging.
18 trains per hour with cross sections comparable to a wide body airliner, probably with double deck platforms. The capacity of such a route would be absurd - its corresponding operating costs per passenger would be astoundingly low.
Does changing trains at the end of the line really inconvenience someone that much when they potentially save lots and lots of money?
Or lets say it is a Maglev, the Maglev could reach Manchester or a spur to the WCML near Manchester (at say Wigan) in 40 minutes or less.
The journey times are still so short that a cross platform interchange still beats the classic compatible solution.
The HS2 structure loading gauge will be big enough for double deck.
And yet it will never be used, because we are going to be stuck with low capacity 200m single deck trains for the forseable future.
