It encourages slick, disciplined working and is anything but sloppy, and better guarantees right time presentation further north. Sloppy woukd be just padding the timetable to have trains wastefully sitting around.
It's sloppy to wilfully operate trains at times other than those which are published. It would be less of an issue if the trains were pick-up only at MKC, but as things stand the railway is advertising a service (the arrival time from EUS) and providing something slightly different, and that, while 1-2 minutes is minor, is simply not being honest.
Trains waiting for time is not time wasted, it's time well spent in ensuring strict punctuality. Again, ask the Swiss.
You don't want "slick" working. You want punctual, reliable working day-in, day-out. I'm even less impressed with this now I know it's deliberate.
The running time from Euston to MKC should be 32 minutes with a 2 minute stop (no stop on an end-doored train should be under 2 minutes, and if a busy stop like Stockport or Old Oak should be 3 or potentially even 4). That is achievable reliably and is what actually happens most of the time. It might be that at present that can't be pathed, in which case I refer back to the "cramming excess trains in" principle, and would hope and expect this to be fixed when HS2 takes most of the fasts off.
With the right platform design, allocation of seats, spreading of passengers ready for arrival, "hustling" should not be necessary at all. How the departure time is advertised relative to actual departure assists this.
More obfuscation of the problem, then. Anyone see a minimum check-in time looming?
(I do like the idea that the published departure time should be the last time at which one can board, i.e. the point the "close" button is pressed, and the published arrival time the point the "open" button is enabled - but that would need to be done nationally, do it just for HS2 and again more confusion)
It simply comes down to that if you're building a multi-billion-pound new railway you shouldn't be cramming it absolutely full on day one. That approach is for things like the WCML where you need to cram in more commuter trains in the peak than it was ever designed to do, and if commuting reduces I'd like to see it backed off. HS2 should be designed so that you can set your watch by it, day in day out. Failure to do this is just skimping, just like not building that extra platform at Euston to save what is, in the overall scheme of things, about 50p.
Resilience isn't sexy, but it's absolutely vital.
To add to this, I've done a bit of searching and it appears DB, for ICE, use 2 minutes at a quieter station and 3 at a busier one. I'd say they've got that right. Old Oak will definitely be a busier one.
