ralphchadkirk
Fighting and restraining people enough to throw them out of a train door would likely leave very specific contusion and fracture patterns.
Indeed - and there were some incidents on ECML north of Newcastle and south of Berwick. A mate was tasked by examining these incidents in BR days - using the new database for accidents that was in then. Amazingly - alcohol featured strongly - in one unfortunate case at , or near Alnmouth - the toxicology report was the highest ever recorded blood /alcohol rate ever recorded in records. One idea was ****ed carry on drinkers - had issues lurching to the buffet car 2/3/4 hours into a journey. Certainly - "events" were reduced over the years....
Would the HST drivers following the ones from which people fell out have been able to spot all those bodies lying beside the track at speed? Would they stop the train immediately and radio in or something, or would some of the bodies go unnoticed for a while on those long desolate stretches? I'm just thinking what the protocol would be for locating someone who disappeared from a train, especially if their family were not aware of them travelling at that specific time. It's not like there's an individual passenger headcount at the start/end of a journey in the same way as airliners.
HSE said:233 The most important failure mode identified, and that posing the clearest risk, is where a lock handle is misaligned so that the lock bolt can jam in the fully retracted position, combined with a door that can stick in its frame. This combination has been found on trains in service, reproduced in laboratory conditions, and the lock jamming effect carefully measured. In this situation the door appears from inside the carriage to be properly closed. A very slight pressure applied to a door in that condition could cause it to open; a passenger leaning on it would be likely to fall out.
They did find that latches could jam and result in doors being closed but not locked but that this was not due to not being properly lubricated, more to do with the tolerances required during fitting and/or maintainence of the locks combined with doors that when closed were a tight fight into the frame (and this isn't a criticism of fitters). Incidentally the report came up with a figure of under 1.5% of locks jamming.I thought the eventual conclusion was that the door latches were found to be jamming if not properly lubricated resulting in the doors in question being closed but not locked?
This seems to have been down to the way BR investigated incidents prior to the HSE report - the lock would be removed from the door in question and sent to Derby for testing, whereas in some cases testing in-situ would reveal a fault, albeit one in which the handle was visibly in the unlocked position when the door was fully closed. Incidentally during the 8 year period (84-91) covered by the report the average number of fatalities per year from falling from trains was 21.TRANS PENNINE
THE MAGAZINE OF THE PENNINE RAILWAY SOCIETY
No.74 - Winter 1990
NOTES FROM THE COMMITTEE TAMWORTH DEATH TRAP
In less than one year 5 people have been killed falling from moving trains in the Tamworth area. In no instance has there been found a defect on a door and BR can offer no explanation. The area has been dubbed the "Tamworth Triangle".
Indeed the report says the very sameThat's the distinction to draw though, HSTs don't have door interlock so they can't obtain interlock with a door open, simply because they don't have interlock. The CDL is only a secondary locking system, the doors if properly closed should keep themselves closed. I don't think the system is in any way unsafe, it just relies on staff performing their duties diligently in checking all doors are closed properly, which I have every faith in them doing.
HSE said:230 The most important finding of the investigation has been that a train door lock that is properly engaged before departure will not come open during the course of a journey in normal service.
Still, if anyone could shed some light on the original story of this topic, I'd be keen to hear it.
PG the hinge at rear of direction to travel is vital , because that door shouldnt have self closed again, and when passing a platform-tunnel etc surely some would have been torn from their hinges? or at least spotted by staff, signalmen etc etc , especially at night ,it would have been like a beacon . so in theory anyone falling from the door with hinge at rear to travel could have exited via the window? pie in the sky? or a mistake from a serial killer?
For people wondering about the CDL system on HSTs having never been "tightened up", the more recent fitment of CDL to 121032 has similar flaws. The system fitted doesn't actually check if the doors are closed, it just confirms there is power to the electromagnets on each door, it's perfectly possible to drive with one or more of the doors open.
