HST power car query.
83G/84D
28 Oct 2011
Cornwall
I was passing Laira over the weekend and noticed a HST power car in the sidings with no cab fitted! As the number is on the missing cab I could not identify it so anyone provide any details?
For anyone in Plymouth it can be seen, albeit through 2 fences, from the footpath off Brandon Road.
It is just about visible from passing trains.
starrymarkb
4 Aug 2009
Exeter
Probably having repairs to the cab (it's a one piece fibreglass moulding that bolts on)
es373
19 May 2011
This may have something to do with the fatality at Hayes and Harlington station a few days ago.
I heard that the cab front managed to fracture on impact and a few of the mounting bolts had bent.
83G/84D
28 Oct 2011
Cornwall
It is facing east so unless it has been turned on the triangle it was on the London end of a train,anyone have an ID for it?
route:oxford
1 Nov 2008
Well, chances are it would have been. Reverse to Drayton Green Junction, then reverse at the triangle before heading Westbound with the undamaged power car leading.
7 Jan 2010
Not likely to be that power car. The most damage caused by fatalities is the nose end door and lower valances getting smashed. A human body would never cause enough damage to require a complete cab swap.
I believe the power car involved at Hayes is currently at OOC.
daikilo
2 Feb 2010
The cab taken out by a tree accross the line several months ago?
dave87016
9 Dec 2008
Lancashire
Does anyone know the powercar numbers that are mentioned above? and I will look up their status on TRUST tommorow
es373
19 May 2011
While I do apologise for questioning your intellect, I have personally changed quite a few cab shells due to hitting animals and mostly humans at high speed.
Cab shells are designed to crumple up on impact as it dissipates the force of the impact rather than carrying the energy down the train.
7 Jan 2010
How tall were these people / animals? The top of the nose end door is over 6 feet off of the ballast!
Normal impact damage from fatalaties is nose end doors, valances, signalling equipment, lifeguards and brake pipes. After that the object is normally in so many small parts that it doesn't cause any other damage.
I'm pretty certain the set involved at Hayes was LA63 if that's of any use. (Power car 43149 rings a bell but don't quote me on that)
7 Jan 2010
I disagree with this also.
The vehicle will have crumple zones in it's structure but there will be no specific weakness designed into a GRP cab.
43067
15 Sep 2010
OOP NORTH
daikilo's quote is what made me think 041, oh well
83G/84D
28 Oct 2011
Cornwall
A person who has posted pictures of this on wnxx.com suggests the identity of the power car is 43036. If so what happened to it?
hello
10 Jun 2008
no fault found, next time you are out and about, i suggest you take a look at the 2 ends of 220001, you will see that one of the ends does not have a dark yellow triangle patch on it where the virgin emblem used to be, this is because after someone took a dive in front of it at early, it did enough damage to it that the whole cab needed replacing
Temple Meads
2 Sep 2010
Devon
I've just found this picture of 43036 (taken on June 22nd 2012, around the time the injured 43 appeared at Laira IIRC) on flickr (not my pic, all credit to the original photographer), the damage doesn't look that serious in the picture, but the fibreglass above the headlight is cracked, and that doesn't look like a separate panel to the rest of the cab to me.
[/url] 43192,43036,Dawlish by 56074 Kellingley Colliery, on Flickr[/IMG]
So all in all, I'd say it is 43036.
DXMachina
24 Oct 2011
short circuit between the tail and headlight power leads caused by compression damage perhaps?
hairyhandedfool
14 Apr 2008
I tend to find the simplest answer is usually the correct one. In this case, perhaps the last driver to use that cab didn't change it over and no-one else checked it.
DXMachina
24 Oct 2011
Are the lights really not linked to the drive circuit to change automatically then?
BestWestern
6 Feb 2011
Hmm, possible I suppose, but it would have been covered up in that case. Most likely it just wasn't checked I guess!
