Hull Trains £10,000 fare
Discussion in 'Fares Advice & Policy' started by TUC, 14 Apr 2015.
Thread Status:
  1. TUC
    TUC Established Member
    1,796
    11 Nov 2010
    Look at BRFares for Selby to Cambridge, I notice that one of the fares available is for £10,000! http://www.brfares.com/#!fares?orig=SBY&dest=CBG -see the 1st class single fares section.
    Doubtless it's an error/there for technical reasons, but I am left curious what the fare is really for. It's marked 'HT DIV RTE ONLY', which presumably refers to some form of Hull Trains diversion, but does anyone know what it actually is for?
    Rail Forums
  3. gazthomas
    gazthomas Established Member
    1,933
    5 Jun 2011
    St. Albans
    Send to the Daily Mail!
  4. najaB
    najaB Veteran Member
    17,065
    I'm sure it's no more an error than the 10p Edinburgh to London first class return fares - it's in there for a reason, but they never intend to actually sell it.
  5. greatkingrat
    greatkingrat Established Member
    1,963
    20 Jan 2011
    There are lots of fares in the database priced at something like 9999.99, it is just a hack to mean "not for sale".
    Presumably it was originally created for days when Hull Trains were diverted via Cambridge due to engineering work.
  6. TUC
    1,796
    11 Nov 2010
    But it still leaves the question of just what it is that it is seeking to prevent a sale of?
  7. ainsworth74
    ainsworth74 Moderator Staff Member Moderator
    18,149
    A Hull trains only first single from Selby to Cambridge which can only be used if they're diverted via Cambridge and also calling there.
  8. jon0844
    jon0844 Veteran Member
    22,232
    1 Feb 2009
    Amazon does this a lot, having things priced at £999,999 - and every now and then it makes the Daily Mail as being outrageous when it's clearly deliberate to stop something showing on searches, and certainly to stop anyone buying.
    Goodness knows what happens if someone did try though! If I was out of stock and put up the price to £999,999, I might try to source something a bit quicker if someone actually ordered!!
  9. PermitToTravel
    PermitToTravel Established Member
    2,946
    21 Dec 2011
    If I recall correctly though, TISes must not offer tickets of £9999.99 for sale; but must offer fares of £10000.00 because that's not a magic number.
  10. Failed Unit
    Failed Unit Established Member
    5,872
    26 Jan 2009
    Central Belt
    They are used for the East Coast rewards tickets. 10p is printed on the ticket but never charged.
  11. jopsuk
    jopsuk Veteran Member
    11,438
    13 May 2008
    There was a period during engineering that Hull Trains were terminating at Cambridge. During more normal engineering situations trains diverted via Cambridge pass through non-stop.
  12. TheEdge
    TheEdge Established Member
    2,887
    29 Nov 2012
    Norwich
    There are all sorts of these tickets dotted within the systems. £999.99 and 00.1p are both common ones on Avantix. Never really understood why they are listed on Avantix, same goes for Advances which for some reason are listed on Avantix (for some routes).
    Is odd its a round number though.
  13. Bletchleyite
    Bletchleyite Veteran Member
    26,611
    Up and down the south WCML (mostly)
    It appears to be blocked from sale a different way:
    From Until Not available on:
    Fri 2 Jan 2015 Sat 16 May 2015 Every Day
  14. jon0844
    22,232
    1 Feb 2009
    I saw a 10p ticket yesterday at King's Cross. It was left in the exit gate (which was open - they all were) and someone hadn't collected it.
  15. TUC
    1,796
    11 Nov 2010
    But what ticket routing availability, in the event of HT being diverted via Cambridge, is it seeking to prevent?
  16. Indigo2
    Indigo2 Established Member
    3,124
    16 Apr 2010
    Reading
    BR Fares now shows fares that have been "disabled" in this way as greyed out. Hopefully that will alert people that something is not right with the fare and that they should take a closer look - in particular this goes for the Virgin SVH Off-Pea Single fares too.
  17. DaleCooper
    DaleCooper Established Member
    2,785
    2 Mar 2015
    No.664 - Next door to the Beast
    Could it be something like a divide by zero error?
  18. TheEdge
    2,887
    29 Nov 2012
    Norwich
    No, because that is commonly known to bring the universe to a screaming halt! :lol:
  19. DaleCooper
    2,785
    2 Mar 2015
    Except in Excel spreadsheets
  20. Indigo2
    3,124
    16 Apr 2010
    Reading
    Yes indeed and there was a slight bug in BR Fares in this regard, which I've just fixed. The fare is actually in the database at £9999.99 but was being rounded to £10,000.00 for display (fares as sold are always multiples of 5p), and as a result the check for fares with a 99p component wasn't catching it. It's now relegated to the "Other" section following Advance Fares, in addition to being greyed out.
  21. trainophile
    trainophile Established Member
    3,130
    28 Oct 2010
    What I find incredulous is that, excluding season tickets, there are 49 different valid ticket options for that one journey. Mind boggling, and I thought things had now been "simplified".
  22. PermitToTravel
    2,946
    21 Dec 2011
    Simplification didn't actually decrease the number of tickets available - it just ensured that they all have the same name.
    To be fair, counting all tiers of advance of a given class as one option (as you're not given a choice as to the price of your AP), there are a mere 24 :P
  23. CyrusWuff
    CyrusWuff Established Member
    1,983
    20 May 2013
    Pfft...That's a miniscule number compared to some routes! Try Birmingham - London. Excluding things like "Inclusive Tour" tickets and Weekend First type upgrades, there are no fewer than 126 ticket options!
Thread Status:
Share This Page
