Hull Trains Additional Services from May 2020
Just been having a good look at Hull Trains for May 2020 onwards
Looks like they adding some extra services
https://www.realtimetrains.co.uk/train/Y20038/2020-05-28/detailed
This one does not stop at Howden or Selby but calls Sandy ??
doesn't seem to be a corresponding working Northbound
Sandy is a pathing stop - the train goes fast line to slow line there to allow 1A02 0530 Leeds to London Kings Cross to pass, then returns to the fast line. This may be to ensure that it doesn't get to Kings Cross too early to go on top of another service in platform 4.
There is a path from Bounds Green for a later train in the evening towards Hull as well.
5H08 2145 Bounds Green T&R.S.M.D to London Kings Cross presumably works something around 2230 towards Hull.
The number of moves off Bounds Green (and lack of empty stock workings at the Hull end) suggests that that will be the maintenance base rather than Doncaster Carr (or Crofton).
https://www.realtimetrains.co.uk/se...8/0200-0159?stp=WVS&show=all&order=wtt&toc=HT
louis97
14 May 2008
Derby
The train actually runs along the slow line from Huntingdon, then returning to the fast line following 1A02 from Sandy as you said.
Peter Bonner
7 Nov 2019
BEVERLEY
You are correct about Bounds Green as maintenance base. Hitachi supposed to be taking it over. Presumably will mean less ecs running from Hull to Doncaster?
James90012
21 Sep 2016
Not a great path looking at all the pathing time but probably a lucrative slot to capture some more of the commuter market, arriving into Kings X just before 8.
pdeaves
14 Sep 2014
Gateway to the South West
I'm not sure whether you mean Hitachi taking over Bounds Green depot or Hitachi taking the Hull Trains maintenance contract. I suspect you mean the latter, but if the former then Hitachi already took over the depot (in November 2018).
James90012
21 Sep 2016
Also, it looks like the 07:59 arrival will share a platform with the first Sunderland GC of the day which sits in platform 4R in the current timetable from 07:05 to 08:27.
TheBigD
19 Nov 2008
There isn't a return northbound path in the system yet. It will be interesting to see if they can get a departure between the current 1548 & 1848 Hull Trains departures.
Class 170101
1 Mar 2014
Surprised it doesn't leave Hull around 04:50 to make Howden and Selby stops possible.
rg177
International Transport
22 Dec 2013
Newcastle-upon-Tyne
I suspect the omission of Howden and Selby is to keep it flexible in case it needs to be sent via Goole due to early morning works.
If they advertise the stops, then that's a bus replacement you've got to run.
robbeech
11 Nov 2015
A very late evening departure would be interesting to see, especially if it calls at the usual suspects such as Retford, might prove useful although likely won't connect to Worksop as the last Northbound LNER that calls that misses it by a couple of minutes due to reasons unknown.
thatapanydude
5 Sep 2018
Bedfordshire
A stop at Huntington or St Neots wouldn't go a miss in that case. Considering the delay at Sandy, a stop at either of these or even Sandy would be fabulous.
Sandy is the furthest station north on the ECML to only be served by a Thameslink in the peaks - so a faster service would go down well.
Who for? There won't be too many people from any of the stations Hull Trains call at who will be wanting to go to Sandy. The last thing they will want is passengers at Sandy filling up their train.
From a practical perspective a stop between Huntingdon and Sandy is not going to happen even if the train has to wait at Sandy.
