Hull Trains disruption 28 Apr 15
Discussion in 'UK Railway Discussion' started by TUC, 28 Apr 2015.
Thread Status:
  1. TUC
    TUC Established Member
    1,821
    11 Nov 2010
    Hull Trains have a significant proportion of their services cancelled or starting/finishing short today. Their website states it is due to a train fault but it looks like more changes than would be caused by a single train set being out of use. Anyone know what the issue is?
    Rail Forums
  3. DaiGog
    DaiGog Member
    235
    23 Oct 2013
    There are only two of the four units in traffic today unfortunately, one set is on exam and another failed on depot ( three are required to run the timetabled service each day). The various cancellations are as per the contingency plans, which are designed to cause as little disruption as possible to the busiest services.
  4. westv
    westv Established Member
    1,577
    29 Mar 2013
    Wonder if it was the set they were going to "reboot" due to no wifi being available?
  5. DaiGog
    DaiGog Member
    235
    23 Oct 2013
    By pure coincidence, yes it was :)
  6. Carlisle
    Carlisle Established Member
    2,179
    26 Aug 2012
    Weren't almost identical FHT problems to this also reported on here about a couple of weeks ago? If so I suppose that's one rather large problem of open access that's not going to be easy to solve ,with costs obviously only allowing for very small fleets
  7. DaiGog
    DaiGog Member
    235
    23 Oct 2013
    The contingency plans vary depending where the failed unit is - for example, if there is one available instead of two at Hull for start of service then the service pattern run will vary somewhat from when the one at the London end fails (the latter was the case today) but in either situation, cancellations are inevitable with such a small fleet unless the maintenance regime allows exams etc to be stepped up at short notice.
    It is indeed a major issue for a small fleet when one unit is on planned maintenance and another fails. Even if there was a supply of spare and available 125mph diesel stock, costs as you say would be a major factor in deciding whether to invest in a fleet expansion when the additional unit would spend a large amount of time sat spare.
Thread Status:
Share This Page
