ICE Diesel Trains
RichmondCommu
23 Feb 2010
Richmond, London
G'day,
As I understand it DB have a fleet of diesel powered ICE units. In terms of sound insulation how do these compare to Voyagers and Meridians?
Thanks in advance,
Richmond Commuter!
3 Mar 2006
GEML/WCML/SR
They are not bad, sound wise is probably similar to most underfloor DMUs as although there was some noise there were less rattles than most UK stock - however the passenger accomodation is significantly better than XC/MML Voyagers. Its not up to ICE1 standards but for a poxy little DMU its pretty good - although not the most comfortable DMU I've sampled abroad (NSB Bm92 wins that) they are certainly OK.
They work mainly on Copenhagen-Hamburg and beyond IC services over the Puttgarden train ferry as seen here http://87015aewn.wordpress.com/2011/04/22/puttgarden-train-ferry/dscf5489/
Mark_Lester
13 Dec 2011
berks
Howard, there's no platform actually on the ferry from what I can see, so I assume you have to get off, you cant actually ride onto the ferry on board the train, or at least if you do you cant then get off for some sea air..
I found this, so I guess there is a platform.
http://www.andrewgrantham.co.uk/as-the-vogel-flies/
Guttorm
4 Jul 2010
Regensburg
You have ride by train onto the ferry, then you have to leave the train and you can board it again a few minutes before arrival, when the announcement advises you to do so.
There is not a typical platform, but I have attached a picture. I know this is no ICE on the picture, but the ferry is still the same so I dont think they have changed the procedure.
WestCoast
19 Jun 2010
I thought quite highly of the ICE-TDs when I have used them. Yes, the underfloor engines feature in the ambient noise, but like all Velaros the quality of the passenger accommodation is definitely superior to the Voyager family...
