IEP for beginners
Discussion in 'Traction & Rolling Stock' started by nickshanks, 14 Jan 2013.
Thread Status:
  1. Zoe
    Zoe Established Member
    5,905
    22 Aug 2008
    I can't think of any, the only section I can think of where 125 mph has even been proposed is Bristol to Bridgwater and even then, the Weston services would not use all of this section.
  2. Robbies
    Robbies Established Member
    1,997
    20 Sep 2009
    Berkshire
    Any routes where 125mph is the maximum speed where it goes beyond the wires such as pass Newbury on the line down to Exeter and the South West.
    Is there also a section of 125mph north of Oxford when going towards Hereford etc..?
  3. asylumxl
    asylumxl Established Member
    4,260
    12 Feb 2009
    Hiding in your shadow
    IEP is not supposed to running on the SW services though. They will remain HSTs for a while longer I believe.
  4. 455driver
    455driver Veteran Member
    11,332
    10 May 2010
    Wouldnt get above about 50mph and the 43 traction motors would overheat/ explode.
    Sounds good.
    Still yuck though unless you give them a decent interior.
    Still a horrible train compared to a decent mark 3.
    But IEP coaches will be heavier and the heavier they are the more you pay.
    TAC is worked out by vehicle weight, number of axles and suspension geometry, I cannot see the IEP elephant being very light on its feet/ nice to the track.
  5. AndyLandy
    AndyLandy Established Member
    1,323
    30 Oct 2011
    Southampton, UK
    Didn't we do this bit already? The IEP bi-mode vehicles are going to come in weighing less than Voyager ones. So, one would expect the TAC to be slightly lower, too.
  6. 455driver
    11,332
    10 May 2010
    Oops I forgot the South West is lucky enough to be keeping the HSTs arent they.
  7. Zoe
    5,905
    22 Aug 2008
    There are no 125 mph sections between Bristol and Penzance or Reading and Cogload Junction.
  8. 455driver
    11,332
    10 May 2010
    Post edited for accuracy.;)
  9. Zoe
    5,905
    22 Aug 2008
    No there is not.
  10. Dave1987
    Dave1987 Established Member
    4,284
    20 Oct 2012
    And there is not a chance that IEP bi-modes could keep to HST timings, whereas a loco could! As the experts have said bi-modes will be very slow at accelerating so journey times will be longer.
  11. ainsworth74
    ainsworth74 Moderator Staff Member Moderator
    19,603
    Can we get a source to verify the statement that bi-mode is going to be slower than HSTs in terms of acceleration?
  12. jimm
    jimm Established Member
    4,545
    6 Apr 2012
    Oops indeed. Now perhaps you could explain how you propose to keep these diesels fuelled and serviced, miles from suitable depots?
    Funny, because some people seem very confident IEP can improve on HST times, whatever the "experts' say. Much of what the 'experts' said was actually about previous incarnations of the IEP, but don't let that get in the way of your permanent negativity, will you?
    And where is the loco that can do all these things you claim for it?
    Unsurprisingly, yet again you have just ignored everything I've said about what operating locos will actually involve for the Cotswold Line. How far from doing a few miles a month, these locos would be hammered up and down, day in, day out, miles from a major depot.
    Just for once, try to break this habit of yours and actually explain how your preferred option is going to work in the light of all those issues I raised? How are you going to overcome them, if using locos is just so much easier?
    Maximum speed currently permitted on the Cotswold Line is 100mph between Wolvercot junction, north of Oxford, and Ascott-under-Wychwood. Network Rail has been looking at the possibilities for increasing speed limits along the route in connection with the introduction of IEP, including 100mph-plus in places.
  13. Metrailway
    Metrailway Member
    556
    1 Jun 2011
    Birmingham/Coventry/London
    The Foster report (http://www.railwaysarchive.co.uk/documents/Foster_IEPReview2010.pdf and http://www.railwaysarchive.co.uk/documents/Foster_IEPReviewAnnex2010.pdf) states:
  14. asylumxl
    4,260
    12 Feb 2009
    Here here!
    The HSTs are actually quite slow in acceleration terms.
  15. Zoe
    5,905
    22 Aug 2008
  16. asylumxl
    4,260
    12 Feb 2009
    Interesting to note, Foster writes a report about IEP and makes those claims, yet isn't aware they will not be going to the SW?
    Also, he will write whatever the administration wants him to.
  17. ainsworth74
    19,603
    As Zoe notes Foster is pretty out of date at this point. I, personally, wouldn't discount his broad conclusions but I suspect a lot of the specifics are now questionable. So anything more recent?
  18. Zoe
    5,905
    22 Aug 2008
    I'm not sure it had been decided for certain back then. The South West was an option on the contract and the decision to retain HSTs wasn't announced until 2011 by which time it was decided that bi-mode would use underfloor engines and the diesel only IEP plan was abandoned.
  19. RAGNARØKR
    RAGNARØKR Member
    539
    1 Jun 2010
    Göteborg
    Depends on the bi-mode, surely? What is the power/weight ratio of the trains?
    He drew attention to a thing called the "constant power curve", which is the limiting factor in acceleration with diesel except on start-up. Whatever you may think of RF, that statement is to be relied on. The implication is that a as the speed rises above about walking pace, there is a limit to the amount of power that is available to be put down at the rail, so that distributed drive wins nothing except when stops are frequent. Voyagers have good acceleration all the way up the speed range because of the high power/weight ratio but the result is to make them into gas guzzlers.
    Hasn't the IEP got negative mass?
  20. Kali
    Kali Member
    180
    5 Jun 2012
    It'd have to be horrendously slow to accelerate slower than a HST. Something like a full 9 car unit hauled by a 67 ( which like a HST also has terrible tractive effort ) to pop that idea...
    Distributed power keeps the axle loading down also. Why are people considering a 68 for haulage? you'd never realistically use any of these drag locomotives for freight, multipurpose is a red herring. Design the train + drag/offwire power unit as a coherent system from the outset.
  21. swt_passenger
    swt_passenger Veteran Member
    19,376
    I think (but have nothing to prove it) that much of the original criticism of the bi-mode dates back to the original plan for a 10 car version of the bi-mode train with a power car at only one end. The published info showed it having the same power unit as a 5 car bi-mode, and Roger Ford gave it the ridicule it deserved.
    Since those times they have binned both end power cars and 10 car bi-modes, so I think the bi-mode power 'issue' has been completely overtaken by subsequent design changes...
  22. asylumxl
    4,260
    12 Feb 2009
    It'd have to be stationary to be slower off the mark than an HST ;)
  23. jopsuk
    jopsuk Veteran Member
    11,895
    13 May 2008
    Thanks to the documents (specifically, the Anglia route ones) linked from this post there's now possible class numbers for IEP- there is mention Classes 800 and 801 from IEp in relation to the length of train Cambridge can handle on platforms 7 & 8, suggesting that even those (which are longer than a 12 car 379/365 by some way) may need extended (for which there is, as noted, lots of space).
    No idea which varients 800 and 801 respectively will be.
  24. krus_aragon
    krus_aragon Established Member
    3,864
    10 Jun 2009
    North Wales
    It certainly has negative press! :P
  25. RAGNARØKR
    RAGNARØKR Member
    539
    1 Jun 2010
    Göteborg
    The inflated costs arise in the first instance from the specification. Bi-mode just helps to pile on more costs still. The inflated cost of new stock is also a very good reason for refurb and keeping old vehicles going for as long as possible.
    Because of the difference in loadings north and south of Edinburgh either the train needs to be split somewhere near Edinburgh or it will be running half-empty beyond Edinburgh. And if the train is to be split, then it might as well run loco-hauled for that part of the route.
    If it is really impossible to split the train at Edinburgh then the handful of trains between London and Aberdeen might as well be diesel throughout. Either way it eliminates the need for bi-mode altogether.
  26. HSTEd
    HSTEd Established Member
    9,512
    The inflated leasing charges for new stock will translate to inflated leasing charges for existing stock.
    The ROSCOs like to make money.
  27. The Ham
    The Ham Established Member
    5,576
    6 Jul 2012
    However as I stated there will need to be less coaches, so even if each coach costs more because they are heaver, say 16.6ppm for IEP compared with 13.6ppm for a Pendilino, it works out comparable per train (9 coaches of IEP and 11 coaches of Pendilino)
    I am talking about track access charges because the track access charges for electric trains INCLUDE the electricity. Therefore the £80,000 that you are so keen for us to "save" would be included in these charges. For IEP to be comparable in track access charges alone to the existing HST's it would need to cost less than 12ppm per coach, however the IEP track access charges include fuel, so it can cost a little more than that.
    To be comparable to the IC225's it could cost 17ppm per coach.
  28. RAGNARØKR
    RAGNARØKR Member
    539
    1 Jun 2010
    Göteborg
    You seem to be the best number-cruncher out there in this discussion group. With your skill (and patience), can you apply this to capital costs, as these are reflected in lease charges? You can make a few assumptions eg that the mark 3 fleet is retained and refurbished at say, £400k per vehicle, that there is some new build of hauled vehicles on top eg to provide driving trailers and DDA compliant vehicles, at say, £1.2 million per vehicle, and that traction is by electric and diesel locomotives at the going rate which seems to be about £3 million a unit. Assume a future life for the mark 3 stock on the basis that it will have to be replaced over the ten year period 2035 to 2045.
    Put this together with the track access charges and fuel costs which you have carefully put together, and then a coherent picture will be visible.
  29. LexyBoy
    LexyBoy Established Member Fares Advisor
    4,461
    23 Jan 2009
    North of the rivers
    I do find it mildly amusing the amount of discussion about comparative costs of IEP vs various alternatives. If there was one metric which I would be confident the DfT had rigorously detailed (and actually have the figures for), it would be cost.
    There are plenty of other things to debate. For example, would people's proposed alternatives to IEP also be
  30. Dave1987
    4,284
    20 Oct 2012
    Sorry just done some research on this. And from what I have read electric is not included in track access charges.
Thread Status:
Share This Page
