Position on the board of Hitachi for Mr Baker ?
Only if we can get the very expensive electrification canned in favour of more expensive bi-modes
I checked a few of the OJEU tender sites as well - they normally react pretty quickly with an award decision, but nothing found so far.
I didn't think you liked the 390s. I'm also not sure much of the GWML would benefit from tilt, the areas where it could be used are to retain HSTs possibily until 2035.
What may make Bombardier smile though is Siemens say they have no interest in bidding for DMU replacements as they consider themselves an electric company
Even if Swansea is electrified, I can't see b-mode getting cancelled as it will still be needed for Worcester/Hereford, Cheltenham and Exeter with HSTs only retained for Plymouth/Penzance.
Or you could retain HSTs on the route, considering a lot of it won't be under the wires.We could of course drag, but then Oxford - Hereford is a long drag.
Kings cross to Edinburgh is a long way to drag a diesel engine under every carriage of an IEP. I wouldn't be suprised if eventually a TOC ripped out the diesel engines and put a loco on the front (maybe even generating electricity for the standard traction motors?)
...It also refers to a Mr Baker and slightly slags him off. Who's he ? Surely you don't mean Norman Baker MP. Although he is a minister in the DfT his brief covers light rail and trams and will not be the one signing off any IEP deal. So slagging him off is totally unjustified.
So what is going on ? I didn't know yesterday and I don't feel I know today either.
Government will be sitting on it until the other major announcement this week. Hitachi Chairman in an interview three days ago said they had just secured the financing for 330 coaches for the GWML, it will take them another year to secure the financing for the 270 ECML carriages. Both Hitachi and Siemens have had trouble securing the financing to underwrite their deals in the current economic climate, probably why the Government has decided to underwrite the Crossrail deal itself.
I did read that the IEP wouldn't be able to run west of Newton Abbot though as it would not cope with the Devon banks. I'm not sure how true this is but if this is the case then I would expect HSTs to be retained for Plymouth services.As to the Swansea electrification killing bi-mode IEP..... this would just replace HSTs as Plymouth/Paignton will already be cleared for IEP, so they would just have all Plymouth terminators being IEPs.
It has been suggested though that HSTs could be life exended to remain in service until 2035. I'm not sure there would be enough 9 car 222s to maintain the current service level to Plymouth/Penzance (I don't think there will be any reductions to this in the new franchise which is Great Western not Greater Western) without a reduction in capacity. That said they could run as 2 x 5 sets.If HSTs are to be retained for Plymouth services, they'll have to undergo another life extension program since their last refurbishment was meant to last until 207-18. When the Midland Mainline is electrified, the Meridians will probably be sent to whoever runs the Greater Western franchise to replace the HSTs.
As things stand, there are no plans to electrify to Exeter never mind Plymouth so electrifying from Exeter to Plymouth would be pointless.A much simpler option would be to electrify Exeter St Davids to Plymouth, but that's too simple for DafT
So what was the main reason to retain HSTs on the Plymouth to Penzance route (possibly until 2035) when this route could have been part of the IEP order, allowing a uniform fleet? Do we know for certiain that the underfloor engines will have sufficient power to cope with this route?This was overtaken by events because soon after it was decided that there would be no 10 car bi-modes ordered, they would all be 5 car - by which stage they had changed to underfloor engines anyway.
Roger Ford covered it all in Modern Railways at the time - that particular point, about them being underpowered for the Devon banks is really no longer a valid criticism of IEP.
So what was the main reason to retain HSTs on the Plymouth to Penzance route then when this route could have been part of the IEP order, allowing a uniform fleet? Do we know for certiain that the underfloor engines will have sufficient power to cope with this route?
Just looking at the franchise consulation, I can't see any plan for a service via Newbury that would terminate at Taunton but I do see plans for a bi-mode Paddington Exeter service with one of these services each day running through to Paignton and these will not be running under the wires for most of their journeys.However Pad to Taunton via Newbury does justify bi-modes apparently.
Where is this Invitation to Tender? As far as I know it hasn't been published and the franchise consultation clearly says that the bi-mode IEP will run to Exeter with one train per day to Paington. It also says that trains between London and Plymouth will likely need to be delivered by alternative stock.If IEP bi-mode cannot handle the track between Exeter and Plymouth, why does the Greater Western ITT include at least one IEP round trip to Paignton and several to Plymouth?
4 trains per hour (tph) London–Bristol Temple Meads; 2 tph running via Bath and 2 tph running via Bristol Parkway. Some of the Parkway trains would extend to Weston-super-Mare and, in the peaks, to Taunton;
2 tph London–Cardiff, with 1 tph serving Swansea, and 1 train per day extending to Carmarthen;
1 tph London–Worcester, with some extensions to Great Malvern and Hereford;
1 tph London–Cheltenham;
1 tph (most hours) semi-fast to Westbury, with some extensions to Exeter and one mid-day round trip to Paignton.
As long as the engines have sufficient power to cope with the banks which it seems they may well do now but not seen anything showing that for certain.I also made the mistake of thinking it included a run all the way to Plymouth, but I can't see the cost of clearing the last few miles from the divergence of the Paignton Line to Plymouth being cost-prohibitive.
