Is travelling via Shipley a permitted route for IlkleyLeeds journeys?
We wish to make a triangular journey: IlkleyBradford Forster Square (which calls through Shipley), then on to Leeds (passing back through Shipley), and finally back to Ilkley, all at peak times. So I was thinking of getting:
ticket 1: ILKLDS return travel ILKSHY then break that journey
ticket 2: SHYBDQ return travel SHYBDQ
travel BDQSHY, using the return portion of ticket 2
travel SHYLDS, continuing on the outbound portion of ticket 1, broken earlier
travel LDSILK on the return portion of ticket 1
But checking the routeing guide, I can't see anything that permits ILKLDS journeys via SHY. This surprises me, since I've done it without problem it's even an advertised route in timetables when there's big gaps between direct ILKLDS trains.
Ilkley's routeing point is Leeds, so page F7 of the routeing guide applies, which says the permitted route is the shortest route or a
route which is longer by no more than 3 miles. I'm pretty sure that going via Shipley adds more than 3 miles on to the journey (anybody know how to check?), which suggests it isn't allowed.
The only easement I can find for this route is number 94, which permits travelling LDSILK via SHY specifically when coming from London, so doesn't apply if you're stopping at Leeds.
The only other discussion of this I've found is Alistair Bell asking a similar question 19 years ago, but the answers aren't clear: https://groups.google.com/forum/#!topic/uk.railway/uEGeAiVm9tE
If this isn't a permitted route, does that mean that the late-night journeys listed in the timetable are only allowed with separate LDSSHY and SHYILK tickets? Thanks for your help.
