Piccadilly Gardens, mostly. But by the time you've gone to Victoria, walked to Piccadilly Gardens and taken a bus from there, and it's wound its slow way through poorly-designed streets, your journey has suddenly got about 20-30 minutes longer than if you just got off the train at Oxford Road. And you've had to pay a bus fare (or tram fare to St Peter's Square) rather than 10 minutes' walk.
Victoria isn't quite in a wasteland to the same extent as it used to be - but it is less convenient for fairly large swathes of Manchester. If anything (and here goes the S-Bahn-Manchester talk again - sorry
@Bantamzen) I'd say it is
more important that local services serve Castlefield (including Deansgate if viable) and that longer-distance services would be fine serving Victoria because whacking 20 minutes on a 2 hour "IC" journey is far less of an issue than whacking 20 minutes on a local commute.
Indeed, should we consider rebuilding Victoria (if the Arena failed because of the proposed alternative out east you've got an amazing chance to flatten it and start again) as a major regional long distance interchange, and turning Castlefield into Manc-Thameslink as I proposed as a 15-16 alternative, with everything from 13 going to the Airport and only local services from Liverpool, Warrington C and Blackpool North feeding into it from the west, and maybe even Kirkby/Southport/Wigan via Atherton instead of it going to Vic?
After all, this is basically what it used to do pre-Windsor Link, with Oxford Road basically being two end-on termini, with the DC Alty and diesel CLC lines serving it from one side and 25kV EMUs from the south from the other way?
It's all very well to say "so, use the tram/bus around Manchester like you do in London", but this is a vaguely similar magnitude of issue as those who were using Southeastern services into London Victoria and all of a sudden found their fast trains (a) getting more expensive, and (b) going to a station 2 miles north of where most of them wanted to go, costing more for a Travelcard and saving them no time whatsoever?
