Increased connection times + LU/DLR zones
17 Aug 2013
Are there any booking sites which allow the user to select increased connection times AND purchase tickets to or from LU/DLR zones?
Essentially I'm trying to buy an advance ticket from Zones 1-2 to Sheringham, using the following weekday itinerary:
Zones 1-2 to Liverpool Street
Depart Liverpool Street (LST) at 16:30 to Norwich
Depart Norwich at 18:55 to Sheringham
The default train from LST for this connection is the 17:00 as it meets the minimum connection time in Norwich, however advance tickets are usually cheaper on the 16:30 departure.
I can book the itinerary on TrainSplit using LST as the origin when I select a minimum connection time of thirty minutes, but TrainSplit doesn't offer tickets from London Zones (which I want to protect against tube delays).
Are there any sites which allow both increased connection times (to force the earlier train from LST) and London zones as an origin?
bb21
Emeritus Moderator
4 Feb 2010
I can't check right now but maybe try WebTIS's Text Only version which has an option for extended interchange time?
Romilly
5 Nov 2013
It's easier than that because the 1630 calls at Stowmarket and the 1700 doesn't. So using e.g. the Virgin Train East Coast journey planner ask for your journey, click on Timetables only, in "Calls at" specify "Stowmarket", click on Update, and click on "Buy tickets".
NB that the journey planner may remember your "Calls at" point for a bit, so if then looking up something different, specify the new journey, go back into timetables, with the "Calls at" box blank click on Update and then on Buy tickets.
17 Aug 2013
Thanks for the replies, tickets now purchased. I hadn't realised that 'calls at Stowmarket' would be such a quick and easy solution.
Romilly
5 Nov 2013
Glad to help, although clearly this method only works when trains on the same line have different calling patterns.
