This morning I didn't think I'd make the 7:12 Southern branded service. I only wanted to board it because the first class is declassified. I'd then change onto the 7:16 service but further in its journey at Effingham Junction.
However the 7:12 was delayed due to a train fault so I'd be able to make it. Also the 7:16 was cancelled due to staff shortages so I'd need to get the 7:35, abet at Effingham Junction.
A member of staff said the doors would open shortly. Thus I knew it was likely to be a door fault. I stood around watching other trains depart.
The departure board explained the reason for the delay. Eventually the doors opened and we could board. By this point there was an announcement about the fault over the tanoy. This was repeated several times in a row, whilst I then boarded the train.
Once on the driver informed us that due to the delay the train would be running fast to Leatherhead. Cue some of us getting off. I wonder if anyone wanted Bookham, which wouldn't get a asrvixs again from Guildford until 7:58. I imagine it's unlikely.
The train then departed. Whilst this happened there was no announcement or update to the departure screens. I wonder how often this happens and is it more likely to happen at a station whose desoture screens are managed by a different company to the one who is running the train or is it just that Govia Thameslink Railway staff couldn't enter in the information fast enough before the train was amended. In this case the info comes from Govia Thameslink Railway. I have a feeling Darwin allows this.
Eventually I boarded a K3 bus. As it got to one point I saw a 281 in front. I decided given this bus was probably running fast, I should get off and join the 281, as that doesn't tend to regulate as much in my personal experience.
The 281 had a osywr card issue with another passenger and the K3 left first. However my Surbtion Crescent the K3 stopped. Our driver waited behind but the K3 aas going nowhere so our driver pulled out to drive around it.
The road works lights were green and we made really good progress Sure enough I got to my destination bus stop 30 seconds ahead of the K3.
This evening there was disruption on the trains due to train faults but the 18:23 to Basingstoke left on time. I didn't however check Clapham Junction or Woking. My mistake.
I decided I didn't have time to walk to the station so I should get a bus. There was a 281 due and a 281 2 minutes away. I decided I'd try the second of the two. I got to the bus stop just before the 281 turned up but not look after the 281 ahead had left.
We eventually over took this 281 and got to Surbtion 30 seconds or more ahead!
As I got off I noticed the train I wanted to catch was running 6 minutes late. It departed 7 minutes late. Thus I could have run for it
However I used the time in between to pop into Waitrose.
We slowed down nearing Woking but passing to our right was a train to Alton. Great. I'll make the connection.
We got into Woking at 18:58. The Portsmouth h triaj was due 19:00.it changed to 01, then 02. Then 03 and finally just delayed with an automated announcement.
It eventually left 19:07, so 7 minutes after the initial estimate.
