Never thought of those as "mainline" though they got misused as suchThe VEP's were a lot more recent than those.
They did have a strong spring on them; I probably couldn't open them when I was little, but I can't recall clearly. I would use my thumb on the latch, but more often opened the window and used the outside handle. I remember a lad from abroad who presumably had not been on a Southern Region EMU before, wishing to alight at New Malden, pointing to the latch and asking 'How?' in a puzzled voice. I showed him how it worked; it wouldn't have been obvious to someone encountering one for the first time.I could never open the doors using the latches as s child. As an adult, I found using the thumb to squeeze the latch works well, fingers less so.
The interior door latch (I think of it as such rather than a 'handle', as you couldn't get your hand on it) on multiple units came I think from a Southern Railway design. I could never manage it until teenage years, it needed a bit of skill and strength, with both thumbs together pushing it, and the next pair of fingers from each hand braced over the end of the mechanism. There must have been a strong spring inside. Few used them.
The only interior handle I recall seeing (and being surprised) was on a new air-con Mk2d on the ECML, first ever encountered. They only lasted a very short while, during which at least one, maybe more, child fiddled with it and fell out, and they were rapidly removed. It seems surprising that the designer could have envisaged any other outcome ...
Interesting that it was a SR design. Does anyone know when internal catches were first fitted? Did any other companies use them?The interior door latch (I think of it as such rather than a 'handle', as you couldn't get your hand on it) on multiple units came I think from a Southern Railway design.
Certainly the G.W.R. stock did not have interior handles. Not only that, but in their 'We're Swindon we're special' design you turned the exterior handle to open the lock and a spring retained it in that vertical position so, after boarding, you had to drop the window and turn the handle back to the horizontal position to keep it shut.Interesting that it was a SR design. Does anyone know when internal catches were first fitted? Did any other companies use them?
Thank you. An aged relative showed me this knack in operating window straps to me on heritage line visit a long while ago. "Just like the windows on the train I took to school!" we were told. He was recalling his commutes on LBSC pre-electrification steam stock.Certainly the G.W.R. stock did not have interior handles. Not only that, but in their 'We're Swindon we're special' design you turned the exterior handle to open the lock and a spring retained it in that vertical position so, after boarding, you had to drop the window and turn the handle back to the horizontal position to keep it shut.
L.M.S. coaches did not have interior handles either but their complication was that the droplight was restrained by a leather strap with holes in - but this did not fully close the window. To do so, you raised the window fully by the strap and then pushed it away from you so that it rested on a sprung ledge. To lower it, you pulled the strap horizontally to pull it off the ledge. All part of everyday travel, but it seems to confuse even guards and TTIs on heritage railways when they encounter one.,
The late Mk2 wraparound doors had the T-shaped handle pivoting in the centre like earlier stock, but possibly for that reason the Mk3s had something more like a conventional door handle with the pivot at one end. Hence you just pushed it down whether the door was left- or right-handed. But any type of wraparound door was much heavier than the earlier ones and could be a real struggle to open from inside on canted track.When 'wrap-round doors' (the wider ones for wheelchair access) were introduced I was initially confused because the doors that opened the 'wrong' way (door hinge on the right) were a complete mirror image of the normal one and had the handle rotating in the opposite direction to open. If you tried to turn it the usual and logical way (anti-clockwise) it didn't budge.
