Invisible Air Pollution
Discussion in 'General Discussion' started by simple simon, 21 Apr 2015.
Thread Status:
  1. simple simon
    simple simon Member
    348
    13 Feb 2011
    Suburban London
    In addition to concerns about ground damage, water contamination and even earthquake formation, there is a new concern; poisonous vapours in the air. As detailed at the links below.
    Simon
    http://www.upworthy.com/the-oil-and...you-things-they-insist-arent-there?g=3&c=ufb1
    Rail Forums
  3. gazthomas
    gazthomas Established Member
    2,234
    5 Jun 2011
    St. Albans
    Crikey
  4. tony_mac
    tony_mac Established Member
    3,420
    25 Feb 2009
    aren't they thermal imaging cameras?
    In which case, while they will help to see VOCs in the right context, they will surely also show entirely harmless things like warm air?
  5. Jonny
    Jonny Established Member
    1,638
    10 Feb 2011
    Walking distance to CLS
    I found this http://www.cem.uk.com/downloads/cem-abstracts/4.11 Steve Beynon.pdf searching through google - it seems that they are using IR cameras. Which means that it could be a load of hot air. Given the website hosting it (Upworthy) it most likely is hot air.
  6. Trog
    Trog Established Member
    1,484
    30 Oct 2009
    The question is how typical is that amount of leakage, as it is some sort of pressure group it is no doubt the 'best' bit of film they captured. It would also be interesting to see video of other industries, and places like petrol stations. An idea of how sensitive the cameras are, and the full range of what they actually detect would also be interesting. The cameras may also detect harmless substances like water vapour, which might not matter when used close up on a pipe looking for a leak. But which would give a misleading impression when used to look at a wider area with more diverse emissions.
  7. the sniper
    the sniper Established Member
    2,176
    4 Sep 2007
    No, no guys. They're "magic" cameras. Answer's in the article on that entirely factual, totally not clickbaity website.
Thread Status:
Share This Page
