Is it only between stns in station group where walking is given
mm333
28 Aug 2008
53.8331°N 1.7734°W
I was on the Dearne Valley stopper this morning, and was going from Ulleskelf to Moorthorpe and then back up to Leeds.
Playing about with NRES, a journey from Sherburn-in-Elmet to South Elmsall, it suggests Sherburn-Swinton-Doncaster-South Elmsall. Whereas a quicker journey is Sherburn-Moorthorpe then the 20 minute walk to South Elmsall.
Does NRES have any walking journeys between stations not in the same station group in the database?
bb21
Emeritus Moderator
4 Feb 2010
Windsor & Eton Riverside - Windsor & Eton Central is one that springs to mind.
wintonian
15 Jan 2010
Hampshire
I don't think Yeovil is a group any more and Ash Vale - North Camp used to come up often as an interchange.
34D
9 Feb 2011
I've seen walking routes from Harringay West to Harringay Green Lanes and they're not a group
tempests1
3 Aug 2010
Haslemere
I'm amused by the notion of someone thinking it's a good idea to walk from Pen Mill to Yeovil Junction: it's two miles down a tree-lined country lane with no footpath. (Luckily there are buses between Yeovil and Stoford that one could catch if one absolutely had to make this interchange.)
I don't imagine there would be the passenger numbers to run a shuttle train on the YYP Branch between PM & Jcn but I guess it is still used for driver route knowledge retention & diversion's Necessitated by engineering work and train service perturbation I guess you could go to Salisbury via Castle Cary & Westbury.
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
Yeah, if you ask NRE for Sherborne to Thornford it asks you to change at Salisbury and Cary (interestingly if you ask for Sherborne to Yetminster—I forgot the order of the stations when I checked—it sends you via Southampton and Dorchester for some reason).
island
30 Dec 2010
Isn't there a negative easement prohibiting people from going via Pen Mill with a ticket to Junction and v/v?
hairyhandedfool
14 Apr 2008
....Does NRES have any walking journeys between stations not in the same station group in the database?
Burnley, St Albans and Windsor had walking distance maps in the National Rail Timetable, presumably NRES still shows them.
route:oxford
1 Nov 2008
Is there anywhere that should have, but doesn't.
Traveline has, in the past, recommended disembarking at Edinburgh Park and walking to South Gyle.
NRE, recommends service to Haymarket then back.
trickyvegas
10 Dec 2009
NRE suggests a walk between New Mills Central & New Mills Newtown and I seem to recall mention on here that they are not grouped.
wintonian
15 Jan 2010
Hampshire
Think you are right there.
Yep there is.
Journeys to Yeovil Pen Mill may not go via Yeovil Junction and journeys to
Yeovil Junction may not go via Yeovil Pen Mill. This prohibition applies in
both directions.
It also appears that in some cases transferring between the two Yeovil stations is mandatory
Customers in possession of tickets routed Thornford Honiton may travel
via Yeovil Junction and Yeovil Pen Mill. These tickets are not valid for travel
via Castle Cary. This easement applies in both directions.
