Is It Possible
nutter
13 Nov 2005
Albrighton, Nr. Wolves, Shrops
Is it possible to make a copy of a train (lets say 170) and then change it so ionly the night cab is available, so you then have a day and a night version.
ie. make the night cab the primary cab
It's just my PC can't handle both, so i only get the day cabs, and i really want to have the option of driving a night train without the cablight on
I'd like to edit all BVE4 trains which have both cabs supplied, so thats all those available from TSC
devon_metro
11 Oct 2005
Yes, easily.
In panel_2.cfg you will see:
Remove the night cab image and replace the #
with:
And then save it, if you want both the night an day cabs available have two seperate folders and use BRR
nutter
13 Nov 2005
Cheers mate, i love doing a bit of coding, i don't use BBR but i can do it manually, i'll keep it simple
ie: a class 170 folder and a 170_night folder
Just made the adjustments to the panel 2, it looks fantastic, with only 3 problems
1) the engine control buttons/lights are still the daytime versions
2) same problem with the horn and reverser
3) same problem with the light controls
Cheers again, BTW, i've added you to MSN
edit: me and Liam have sorted it all out with the 170, it looks amazing
Derek Kaye
9 Jun 2005
Loughborough
Nutter, I had a problem similar. For me, the only time that glow and day/night cabs work properly is when you run BVE in full screen mode.
nutter
13 Nov 2005
I always run it in full screen mode, it's cause i have a 124mb graohics card, which is SiS which don't help, and only a 256mb RAM, so the computer simply can't handle both cabs, only one
I'm telling you what, I really can't wait to get a new computer, so i don't have to do all this coding.
I enjoy it, but all the time
I've had to edit all the trains 3 times because i have 3 different directories, so i'm retty board with coding at the mo, all though i'm still enjoying route coding *cough* ;)
Lewisham2221
23 Jun 2005
Staffordshire
dvn1357 said:
Its not the graphics mate, mine is only 64 :lol:!
It isn't just the amount of video memory that makes the difference there. The actual GPU (graphics processor) on the graphics card makes the most difference, although the extra memory does help.
