Is the Class 66 the black 5 of Diesel locomotives?
Discussion in 'Traction & Rolling Stock' started by Trainfan344, 23 May 2015.
Thread Status:
  1. Trainfan344
    Trainfan344 Established Member
    1,991
    13 Oct 2012
    So we all know the black 5's were the go anywhere, do anything steam loco's but are the Class 66's the same with Diesel loco's? Is that the reason so many were built?
    Rail Forums
  3. 455driver
    455driver On Moderation
    11,332
    10 May 2010
    No, they cannot work passenger trains as they have no train supply.
  4. ainsworth74
    ainsworth74 Moderator Staff Member Moderator
    18,841
    Apart from where generator cars are available as I've been on 66 hauled tours ;)
  5. Dieseldriver
    Dieseldriver Member
    483
    9 Apr 2012
    I'd argue that class 47s are probably more likely the 'Black 5' of the diesel era.
  6. ac6000cw
    ac6000cw Established Member
    1,590
    10 May 2014
    Cambridge, UK
    I agree, and the 37s would also be a contender (especially as - being lighter - they have a wider route availability than a 47).
    Of the modern stuff, the 68s maybe ?
  7. ainsworth74
    18,841
    I was thinking 68s as well. Capable of nearly any passenger duty and most freight turns as well. The only thing I'm wondering about is their route availability sufficient for them to be used in most places?
  8. GB
    GB Established Member
    5,229
    16 Nov 2008
    Somewhere
    The class 68 is significantly lighter than a class 66 but only has 4 axles instead of 6 so I believe both classes are RA7.
  9. theblackwatch
    theblackwatch Moderator Staff Member Moderator
    9,595
    15 Feb 2006
    The 66 can't 'go anywhere' - they are unable to traverse a number of lines in Scotland, such as Oban (which has a RA5 restriction on it), and special dispensation, coupled with some extra speed restrictions, had to be given for one to go to Mallaig on the Royal Scotsman.
  10. Juniper Driver
    Juniper Driver Established Member
    1,747
    17 Jul 2007
    SWR Metals
    Definitely.
  11. route:oxford
    route:oxford On Moderation
    4,644
    1 Nov 2008
    Is there anywhere a 37 can't go?
  12. 61653 HTAFC
    61653 HTAFC Established Member
    8,911
    18 Dec 2012
    Another planet...
    Up until about 8 years ago they couldn't go South from Huddersfield towards Sheffield due to restrictions on the first viaduct out of HUD. Though that applied to all locos, rather than being specifically 37s. There's probably a few other places where locos of any kind are barred.
  13. bigdelboy
    bigdelboy Member
    198
    9 Apr 2012
    I'd be thinking of a class 66 as more of a LMS Stanier 8F or BR standard 9F because of the freight orientation.
    The comparison becomes convoluted wrt passenger working :: arguments might bring in thoughts of the class 66 'cousin' the CIE 201(ii) class ... and the fact 8F as apparently derived from Black 5. Too hard to dig down there though for me.
    All said I'd vote the class 37 as earning itself the crown over many years as the 'Black 5' of the Diesel .... not really quite up to the 'top notch' passenger working but (sometimes) solid mixed traffic performance. ( Class 47 i'd regard as more aligned with say BR Standard Class 7).
  14. cjmillsnun
    cjmillsnun Established Member
    2,832
    13 Feb 2011
    No the Duffs were.
  15. D6975
    D6975 Established Member
    2,007
    26 Nov 2009
    Bristol
    A small number of 37s had the horns moved from the roof to the top of the nose to enable them to go to some places in Healey Mills territory with restricted clearances. Was the Penistone route one of them? Or was it just a weight over the viaducts thing?
  16. Peter Mugridge
    Peter Mugridge Established Member
    9,467
    8 Apr 2010
    Epsom
    Is the Thameslink Core still restricted to 31s and 73s only as far as locomotives are concerned?
  17. 61653 HTAFC
    8,911
    18 Dec 2012
    Another planet...
    The Penistone line block was solely down to weaknesses in the metal framed spans of Longroyd Bridge/Paddock viaduct which I believe was imposed around 1992. As far as the ones with modified horns were concerned, it wouldn't surprise me if one of the problem routes was, until 1983 at least, the Clayton West branch. Shelley Woodhouse tunnel I think was quite tight vertically, though built wide enough for double track. The stock running through there now of course fits easily!
  18. TorqueOfTheDevil
    TorqueOfTheDevil Member
    271
    27 Feb 2007
    What happened for engineering trains/test trains etc? Was it simply that permission was granted for locos to cross the viaduct on infrequent occasions?
  19. alexl92
    alexl92 Established Member
    1,572
    12 Oct 2014
    With most test trains around Hudd being Class 31s which have RA5 like a Class 20, surely they'd be allowed over?
  20. matchmaker
    matchmaker Member
    848
    8 Mar 2009
    Central Scotland
    37s are also RA5.
  21. 455driver
    11,332
    10 May 2010
    As were the Deltics!
Thread Status:
Share This Page
