Island Line Upgrade updates
The_Van
28 Nov 2011
The Stort
That's scuppered it anyway even if they could get 2 units working. No travel between tiers 2 and 1 allowed I guess
pompeyfan
24 Jan 2012
The SWR Twitter feed replied to a regular enthusiast earlier, stating they believed that a unit was unlikely to see service again and that they believe a 1 train service will be in place from next week to allow crew training.
MotCO
25 Aug 2014
Will they run the new trains purely to train the crews (i.e. with no passengers) alongside the old trains?
Chris125
12 Nov 2009
They won't enter passenger before the 3 month blockade next year if that's what your asking?
MotCO
25 Aug 2014
No, I was thinking would you see both 483s and 484s running on the track at the same time, the 483s carring passengers and 484s training drivers?
pompeyfan
24 Jan 2012
Yes I would imagine you would see them pass at Ryde St John’s road and Sandown
VEP3417
27 Jun 2011
Hampshire
Worth keeping an eye on this facebook page, Richardson Rail have posted photos of the recent 484 move and the track lowering back in August:
interesting to see theyre fitting wooden sleepers, i thought "the railways" where moving away from wooden sleepers to either concrete or the recycled materials ones, unless because the line has a low traffic movement theyre deemed to be ok in that case so would wear out/deteriorate less compared to a main line/heavy use
They also have to achieve their fault free running hours/miles for acceptance as well...
Mollman
21 Sep 2016
Sorry if wrong thread but if one of the 483s is being preserved then it would make sense for SWR to organise a farewell event next year using the preserved unit. This would avoid the issues covered above regarding people visiting IoW in December. Is there anything in the infrastructure upgrades which would prevent this?
VEP3417
27 Jun 2011
Hampshire
yes as the trains are being withdrawn in december (or by the beginning of jan anyway) before the works start i believe
Chris125
12 Nov 2009
I think they were planning to install TPWS? That would scupper any use of the 483s I'm afraid.
cav1975
24 Sep 2010
That's one part of the project that I never understood. The train stops are simple and 100% effective as well as compliant with the regulations. So why go to the expense of TPWS? 484001 seems to be equipped with train stops too.
Gloster
4 Sep 2020
Up the creek
At a guess, if it is so fitted, it is probably because TPWS is the standard now and nobody dares say, “Hang on, that’s ridiculous over-provision for a line like this.”
Chris125
12 Nov 2009
No great surprise they want to remove something so non-standard, especially as more trainstops would be needed for the loop at Brading - however TPWS may also allow shorter section times, as it was mentioned last year in connection with running a 20min service.
Journeyman
16 Apr 2014
Personally I welcome Island Line getting standard kit that's used elsewhere. We shouldn't be complaining about it!
Chris125
12 Nov 2009
I guess it depends when they interviewed the SWR bloke - I must admit I was beginning to wonder why we haven't seen a planning app for listed building consent, it's only three months to the blockade now.
I'm surprised that there's still no real detail of the work with weeks to go - if they were planning to re-use the old platform at Brading shouldn't they have applied for listed building consent by now? They did for the wi-fi...
I had a look at the planning applications for the overlay platform surfaces at Ryde Esplande and Pier Head. For level boarding of a class 484 they intend to provide a 375mm height increase at Esplanade, and 477mm at Pier Head. That’s probably as good a reason as any that 483 and 484 would never have been able to operate safely together...
K.o.R
6 Dec 2017
That is a BIG change in height!
Chris125
12 Nov 2009
I hadn't noticed those, at least it shows they're making some progress so fingers crossed we'll see one for Brading imminently... and for those Doubting Thomas's out there, they confirm 4-car trains.
(20/02182/LBC and 20/02161/LBC for anyone looking on the planning portal)
...hang on, platform gap fillers at Pier Head?
To achieve PRM level access boarding (with no additional boarding aides) on the curved
section of platform it will necessary to procure and install platform gap fillers to reduce
the platform gap to within 75mm.
Yes they’re relatively new, within the last fortnight, so it could be the local authority are rattling through a backlog.
I suppose the nature of the two stations here is that they cannot lower the track, ie we mustn’t assume there’ll necessarily be overlays elsewhere?
richardlong
25 Nov 2020
Interestingly the track at Pier Head was raised in 1966/67 (rather than lowering the platforms as was done at Esplanade) so presumably they could have chosen to lower it back down again.
