Issue with Maidstone East Line (BVE)
joshcoupe
25 Oct 2011
Maidstone
Hi all,
I am trying to get the Maidstone East Line up and running (the version from BVE in Kent) and I am having some major issues. I am using BVE 4 (as recommended) however none of the objects can be found and I am left with a blank white screen. I have checked this is not a route error as I have found some youtube material.
Can anyone tell me where I'm going wrong. My folder structure atm is:
Route:
C:\Program Files\BVE\Railway\Route\Ashford-Victoria\Ashford-Victoria
Objects:
C:\Program Files\BVE\Railway\Object\seastV2\seastV2
Any help will be grand thank you!
Josh
hinko
10 Jun 2007
hi josh,if it helps my files are such c:\program files\mackoy\bve4\railway\route.
and if you start bve4 it should come up with all your routes.
objects are in c:\program files\mackoy\bve4\railway\objects and all you route objects should be in that location. all sounds should be in c:\program files\mackoy\bve4\railway\sound so when you first run bve4 you should get a list of routes and if you go to the drop down menu you should have a file like railway click on that and it should list route/s object/s sound/s. i hope that makes some sense regards hinko:|
carriageline
11 Jan 2012
Where did you get the trains etc from for this route? That's the part im stuck on :(
