Jump to neutral?
rbruce1314
30 Jul 2005
up a gum tree
A while ago I (re-) installed BVE4 from scratch onto a newly formatted hard drive. Previously it had worked perfectly but now tthe reverser randomly jumps to neutral (all lines, all traction). I had asked around and was told it was a gremlin in my PC, but now I see in the 'how to run BVE in Vista ....' thread that someone else mentions it as if it were a command that can be switched on and off. If that's true, how do I do it??
Ta.
Gavelex
9 Sep 2006
london
is it just the cab pic that goes into N? Or is there no power either? if so I get the same probblem, I presum it is a bug in BVE.
Cheers,
william
13 Jul 2007
Durham
Is it not the AWS/TPWS saftey devices triggering off. Some traction and lines this seems to be a problem for me, i.e. doesnt respond to the 'insert' and 'delete' buttons, yet others, such as the 158 seem to work fine?
D306
9 Apr 2007
somewhere concrete
It seems to only b e affecting the 1995 stock, as when I play BVE with that, it always does that after about 20/30 mins of driving the train. or straight away when I'm driving.
rbruce1314
30 Jul 2005
up a gum tree
Cheers,
Not just cab pic, power itself goes off. Sometimes when you ease the brake when stopping, sometimes as you power up, and sometimes just when it feels like it!!
Blockman
19 Dec 2007
Did you ever get to the bottom of this? I have exactly the same problem, and nothing I have done so far will fix it.
