King's Cross Disruption 15 Feb
Discussion in 'UK Railway Discussion' started by Norther Monkey, 15 Feb 2020.
  1. Norther Monkey
    Norther Monkey Member
    199
    7 Aug 2011
    Ongoing problems at King's Cross today - it seems to be taking a huge amount of time to clear a 'broken down train'. Purely out of curiosity could anyone offer any further explanation?
    Rail Forums
  3. Edders23
    Edders23 Member
    550
    22 Sep 2018
    Trains between Peterborough and Stamford are getting delayed due to a broken down freight train but not sure if that is on the ECMl or just in the Peterborough area
  4. Southern Dvr
    Southern Dvr Member
    457
    13 Oct 2010
    2 broken trains at The Cross this morning with only 2 platforms available to LNER, that meant there was no room at the inn until they fixed them!
  5. The North Briton
    The North Briton Member
    142
    28 Feb 2009
    Unable to release the parking brake on the DVT of the first departure 0701 to Leeds. Short of leaving the DVT on the stops (which was under consideration at one point), not a lot you can do. Finally moved off after 1130, after multiple Up services were turned around short of London or recessed in loops.
  6. jon0844
    jon0844 Veteran Member
    24,435
    1 Feb 2009
    I believe at least one train started from Stevenage to Edinburgh? Went out from platform 1 which must have looked odd.
  7. Norther Monkey
    199
    7 Aug 2011
    Could this set have run in passenger service without the DVT?
    If so, if another DVT wasn't immediately available could a Class 91 or other loco have replaced the DVT to allow running in both directions?
    I'm not suggesting any of this was practical today, just curious about what's possible.
  8. GregA
    GregA Member
    120
    14 Dec 2018
    I understand they can run without the DVT without a problem as long as the 91 is running "sharp end" first (as they normally do). When the train reaches its destination the 91 has to run round the carriages and then take the train back, running "blunt end" first; when running like this the train is limited to 110mph.
  9. rick pike
    rick pike Member
    60
    6 Jan 2013
    Grimsby
    I thought that a passenger train must have at least one vehicle with a parking brake in the consist. So Im surprised that they considered leaving it behind. Also the couplings are not the standard buckeye within a set of mk4s. Think it's called a tightlock.
  10. Marton
    Marton Member
    597
    9 Nov 2008
    Can this not also be managed in Newcastle by using the HLB?
  11. The North Briton
    142
    28 Feb 2009
    I should be clearer: the set was only going to go to Bounds Green, with or without the DVT. Leaving it behind would have freed up the platform for a 5 car unit, but obviously then left the problem of recovering it.
  12. Ianno87
    Ianno87 Established Member
    6,262
    3 May 2015
    Then the whole set ends up the wrong way round back in London, which is a nightmare if the set needs to Bounds Green that night (i.e. doesn't line up with equipment in the depot, etc). And the wrong way around compared to all available replacement DVTs.
  13. Norther Monkey
    199
    7 Aug 2011
    I understood all that, but it was a horrible afternoon therefore perfect for asking 'what if' questions. Thanks to those who responded.
  14. Snow1964
    Snow1964 Member
    254
    Kingston upon Thames
    My daughter was on the 07:01 from Kings Cross, going to Sheffield via Doncaster (as MML shut)
    She said the announcement was a problem with the air (she might have missed bit of announcement)
    Everyone had to change to 07:24 (platform 7) which then left late as 07:01 was then cancelled
    Coming back she was routed via Retford, but her Hull trains connection was cancelled (I think it was skipping stations, so had to get later connection). Strangely Hull Trains website reasoning was to avoid overcrowding (presumably they didn't want the 2 reserved seats being used, which defies logic)
Share This Page
