Do you really need to go to the main concourse? Least walking is via the Hammersmith & City which gives direct, overbridge, access to the 'British Rail' platforms without going to the main concourse. H&C trains are direct from Kings X ... no need to change. There is also a coffee shop between the H&C gate-line and the access to the 'British Rail' platforms if you have a wait.
The access to the concourse isn't bad either. Steps or escalator.
Each time I used Paddington inbetween lockdowns there as a one-way system in effect and the barriers on the overbridge were set to exit only.
Thank you all for your assistance with my query, I am travelling First class to Penzance so presumably it is a 2x5 car 800 and I am better in the front portion, although I need to check my reservation on that one.
The main reason I put concourse in the header is because I will be going to Sainsbury's or M&s to stock up with supplies for the 5 hour journey.
Sainsbury’s Local at Sheldon Square is closer to the H&C platforms at Paddington than the Sainsbury’s Local on the main concourse.
Come out of the H&C barriers, go up to the canal via the steps next to Costa Coffee, turn left and walk along the canal, under the road bridge and you’ll see Sheldon Square on the left.
Yeah I was about to suggest this.Good point about using M&S or Waitrose as Kings Cross.
An Eastbound/Clockwise circle from Kings Cross via Tower Hill and Victoria would (eventually) take you to Paddington circle on the side which doesn't require the steps over the C+D line there.
Would take about 45 minutes, rather than 12 going West to the H&C platforms.
Edit: I misread this as Victoria-Jubilee.you can also do southbound Victoria line to Green Park, cross platform to northbound Victoria line back to Oxford Circus
Which is what I said - southbound Victoria line to northbound Victoria line. This then avoids steps at Oxford Circus for the transfer to the northbound BakerlooNot correct — at Green Park the cross-platform opportunities are Victoria Northbound/Southbound, or Jubilee Northbound/Southbound. To change between those lines there involves short steps, a short corridor, and an escalator. Anything involving the Piccadilly is even worse, and best avoided even by the fit and mobile.
