Kwvr diesel weekend
badger1badger
24 May 2010
Morning
We are visiting the diesel day next week
On the timetable from keighley to damems there is 5 minute wait before the train back to keighley -
Is this enough time or is it possible to miss the train back ?
Which other cross over points are on the route so as to maximise the haulage with out waiting at stations too much
Cheers
Paul
caliwag
29 Mar 2009
York
Well from what I know of KWVR, you'll wonder what to do with the 5 minutes as the passing loop is to the Howarth side of Damens which is about one coach length...request stop mind.
badger1badger
24 May 2010
Ah ok - just trying to be as flexible as possible
Which coach stops at the platform ?
Paul
YorkshireBear
23 Jul 2010
Paul
In normal service the carriage behind the loco stops at damems i presume it will be the same on the diesel weekend, ask staff to be sure though.
And even if your train from keighley to damems is 15 minutes late it is impossible to miss the train coming back down. Damems is a single platform before the loop so the train you get from keighley to damems has to leave damems and go into the loop before the other service to keighley can come into damems. So 5 minutes is definitely enough :)
badger1badger
24 May 2010
Great yb - thanks
JamesHorrell
21 Sep 2010
Keighley
The Coach which pulls into the station on all events is the first coach and also damems station is good for swaping trains,If you want to go back down to keighley and then oakworth if you want to go back up to haworth as damems loop is the only place 2 trains can pass and if you get off at damems or oakworh they is usally a 10-20 min wait for another train.
