Lancaster to Newcastle
mbga8mjb
16 Jan 2012
Hi, I need to go from LAN to NCL (return), leaving tomorrow coming back on Saturday. I can't be specific with my times, so the anytime return £47.40 is what I'm going for. I need to come back late on Saturday and I recall the last train south from carlisle is quite early, so had a look what the permitted routes are.
The routing guide suggests I can go down the east coast and across the pennines from york according to NC+MH+TP but when I go onto NRE and also trains-can-be-cheaper to check the route, nothing is coming up as valid.
I would have thought Newcastle - York - Halifax - Preston - Lancaster would be allowed? Am I missing something?
SickyNicky
Verified Rep - FastJP
8 Sep 2010
Ledbury
You need to consult the maps in order and must use all of them. To travel
(or the reverse journey in this case), you don't use map MH, so it's not a permitted route. It isn't merely enough to pass through a single routeing point on a map, you must use at least one link on each map.
No doubt now others will disagree, but that's certainly my interpretation of the rules.
8 Jun 2009
It doesn't appear to allow the direct line from Bolton to Preston, instead you have to go Bolton > Blackburn > Preston (to include map MH). Insane.
You can trace:
Lancaster > Preston > Blackburn (on NC)
> Bolton > Manchester > Stalybridge (on MH)
> Huddersfield > Leeds > York > Darlington > Newcastle (on TP)
But since you have to use MH you can't go via Halifax.
Oscar
Fares Advisor
11 Feb 2010
Switzerland
If you do decide to go via Carlisle, you should consider a Clapham Yorks - Newcastle Via Carlisle Anytime Return valid via Lancaster and Carlisle.
snail
16 Jun 2011
t'North
It doesn't sound intuitive, given that there are direct services between York and Preston via Blackburn (map TP) but to use York-Manchester-Bolton-Blackburn-Preston you have to change at least twice.
Where do the instructions prohibit 'passing through' if that happens to be where the maps touch?
jkdd77
16 Nov 2008
You can trace:
Presumably it would be possible to buy a Leeds- Blackburn single to "bridge the gap" between the point where the ticket ceases to be valid and where it becomes valid again, having 'notionally' travelled on map MH?
They don't explicitly prohibit that, but they do say:
HOW TO USE THE NATIONAL ROUTEING GUIDE
STEP 7
Identify the route to which the code(s) refers using the maps
Each code refers to a map. If a single code is indicated the route is via any
route on that map from the first routeing point to the final routeing point
without doubling back (passing through the same station twice on a single
journey).
Where a routeing specifies that a combination of Maps be used e.g)
ER+PN+BD, the route is via any route on that map from the first routeing
point to intercept point(s) for the next map without doubling back, then via
any route within that map without doubling back. This is repeated until the
final map is reached then via any route within that map until the final
routeing point is reached.
Example (e) - Darlington to Shrewsbury via permitted route ER+PN+BD. This
allows travel from Darlington to York via Map ER, York to Manchester via Map
PN and Manchester to Shrewsbury via Map BD.
ALL MAPS NEED TO BE CONSULTED IN SEQUENTIAL ORDER.
DO NOT USE THE MAPS UNTIL YOU HAVE FOLLOWED STAGES 1 - 6.
You could buy a ticket to "bridge the gap" however what I'd do is obtain an itinerary for the longer route, and then ask the guard if you have permission to go via the shorter route.
Guards will, in nearly all cases, allow reasonable routes. If a guard believes a route is unreasonable, the guard may declare it invalid (whether it is or isn't) and take it from there, or, more correctly, seek clarification from Control regarding whether it is valid or not. A small number of guards carry a copy of the Routeing Guide (and some ask on here and I've answered some queries via PM) but that is unlikely, so most would need to contact Control, unless they had good knowledge of the Routeing Guide. I suspect many will not do that and charge a new fare that can be refunded (or UFN that can be cancelled) if it turns out they were wrong.
I'd say that using the ticket via Burnley is likely to be considered reasonable by the vast majority of guards, however using the more convoluted route that is permitted via Manchester is actually at risk of being deemed unreasonable, despite being valid. A guard will not know it is valid (unless they've read this thread; which is quite possible on this route ;)).
If a passenger is on a permitted route that is deemed unreasonable (by the guard; of course it's subjective), then it can result in being charged a UFN which may then have to be contested, or sold a new ticket that then has to be refunded. On some occasions the Routeing Guide is then changed as a result. Many customers choose not to use routes that are permitted that are likely to be considered unreasonable because they do not want the hassle that can result, despite being in the right.
mbga8mjb
16 Jan 2012
Thank you for the responses - like someone said, the idea of York - Manchester, then Manchester to Blackburn then Blackburn to Preston then Preston to Lancaster just seems a bit strange.
Where is it documented in the routeing guide you have to use all the maps? It does seem bizarre that York - Preston is not permitted because you're missing out one of the maps!
EDIT - Thanks Yorkie - I think we posted at the same time.
EDIT - NRE is showing the 19:03 NCL to YRK then 20:13 YRK to PRE then 23:05 bus to LAN as a valid itinery. Does than mean NRE ignores the routeing guide? I guess I'll print the itinery and show it to the Guard at York?
