Dorking to Horsham is now down to one train per hour. Used to be the main line way from London to Bognor etc.
Carnforth Traincrew depot only closed around 14 years ago, but perhaps sectorisation meant they lost the work you refer to long before that .I seem to remember that once Carnforth train crew depot had closed, these trains seemed to change locos at Preston.
Ignoring Covid, Newcastle to Edinburgh is 3 electric trains per hour each way, 1 x TPE and 2 X Lner.Too many candidates here.. triangles out there with no workings, for example the actual mainline at Dinting - platform 1 is about 4 a day, do they count.
Just to get a Woodhead answer into every trivia question. They score double points.
Or the south curve at Carstairs. Less than hourly.
Actual multi-mile mainline?
The almost complete Church Fenton to Colton J. Only TPE's 802s can do it, and there is 1 or less an hour each way.
Even Edinburgh to Newcastle is mostly 1 an hour each way.
Yes....sorry, I could have phrased that better. It became a Trainload Freight only depot on sectorisation in the mid-1990s.Carnforth Traincrew depot only closed around 14 years ago, but perhaps sectorisation meant they lost the work you refer to long before that .
Err....is that not only two electric trains per hour?Ignoring Covid, Newcastle to Edinburgh is 3 electric trains per hour each way, 1 x TPE and 1 X Lner.
This has got to be the oddest bit of line on the post-Beeching network! I can only assume that it was electrified to cater for heavy freight traffic running south from the Potteries back in the day, because up until the WCML modernisation there was just one passenger train per hour in each direction. As of 2019 that frequency has doubled but there's hardly any freight that I could see. And said modernisation seems to have passed it by - it's still stuck in a peculiar sub-100mph 1960s timewarp.What about the Colwich Junction - Stone line at the moment?. Many of the London - Manchester services are going via Crewe.
Err..... Its a typo by me, tpe x 1 tph, lner x 2 per hour!!!Yes....sorry, I could have phrased that better. It became a Trainload Freight only depot on sectorisation in the mid-1990s.
The line from Nessargues to Beziers is electrified and once had main line services. There are no through passenger trains, the first part is by coach and then emu from Saint Chely d'Apcher. One service a day. This removes the possibility of travelling over the Garabit Viaduct.There'll be loads of international examples. For example the Paris-Orleans-Limoges-Toulouse classic line has only a handful of daily services on some sections.
But still only 2 electric trains per hour in places (LNER) - notably the section between Chathill and Longniddry with TPE being required to run on diesel until such time as the power supply upgrades are completed.Err..... Its a typo by me, tpe x 1 tph, lner x 2 per hour!!!
Ok cheers, I remember that often long line of class 31s berthed in the siding next to the depot .Yes....sorry, I could have phrased that better. It became a Trainload Freight only depot on sectorisation in the mid-1990s.
Quite the reverse, actually. Avanti only had a handful of route retention London-Manchester via Crewe trains each day between December/January(?) and the May timetable change.What about the Colwich Junction - Stone line at the moment?. Many of the London - Manchester services are going via Crewe.
Also, the Aston - Stechford section of the WCML?
When the WCML electrification was extended from Weaver Jn to Scotland in the early 1970s, BR also electrified the 3½ mile alternative route between Winwick and Golborne Jns via Earlestown and Newton-le-Willows.The original WCML electrification around Crewe, Liverpool, etc got very profligate in how far they wired down the various side lines.........
I'm sure they have done, or will do, when the Mains are blocked during engineering works.The Relief lines between Cardiff and Severn Tunnel Junction have never carried a revenue-earning electric train as far as I'm aware.
Hope so. I want to do the Bishton flyover in an 80x (or even a 387!)I'm sure they have done, or will do, when the Mains are blocked during engineering works.
Apart from presumably very occasional diversionary use when the direct line was closed, these wires went unscraped for 40-odd years until they were incorporated into the Chat Moss electrification in the past decade.
I wonder if authorisation of the original Earlestown OHLE was related to the former Motorail terminal at Newton-le-Willows? This was in operation at the time the northern WCML electrification was planned & approved (presumably in the very late 1960s) with services to/from Scotland and the West Country.
Unfortunately those particular Motorail trains were withdrawn just before the wires were energised in 1973, so never saw an electrically-hauled departure (although, IIRC, the two Motorail sidings at NLW were wired).
When the electrification opened in 1973 a daily local Class 304 emu started from Crewe to Preston and back, which went this way. It ran for some years. Apparently it was a sinecure diagram for a Crewe driver approaching retirememt, left Crewe at about 09.30, couple of hours for lunch at Preston, home by teatime. Given up maybe around 1980. It stopped at both Hartford and Newton-le-Willows.I wonder if authorisation of the original Earlestown OHLE was related to the former Motorail terminal at Newton-le-Willows? This was in operation at the time the northern WCML electrification was planned & approved (presumably in the very late 1960s) with services to/from Scotland and the West Country.
Maybe, but 2P82 09:17 EMU Crewe-Preston in the May 1974 WTT used the main line between Warrington (d. 09:42.5) and Wigan (a. 09:54). It went to Carnforth, not advertised 1 July to 27 September. 2K82 15:00 Preston-Crewe seems to be the return working, not calling at Hartford, whereas 2P82 called at Hartford in the down direction. WTT extract from Section G 6 May 1974 to 4 May 1975.When the electrification opened in 1973 a daily local Class 304 emu started from Crewe to Preston and back, which went this way. It ran for some years. Apparently it was a sinecure diagram for a Crewe driver approaching retirememt, left Crewe at about 09.30, couple of hours for lunch at Preston, home by teatime. Given up maybe around 1980. It stopped at both Hartford and Newton-le-Willows.
THat picture appears to have clipped off too much to have any useful informationMaybe, but 2P82 09:17 EMU Crewe-Preston in the May 1974 WTT used the main line between Warrington (d. 09:42.5) and Wigan (a. 09:54). It went to Carnforth, not advertised 1 July to 27 September. 2K82 15:00 Preston-Crewe seems to be the return working, not calling at Hartford, whereas 2P82 called at Hartford in the down direction. WTT extract from Section G 6 May 1974 to 4 May 1975.
EDIT The following year (1975-76) 2P82 became 1P82, no longer ran to Carnforth, but ran in the same timings. 2K82 became 1K82 in the up direction.
The 1974 EMU service (SX 1/7 to 27/9) to Carnforth was unusual for sure.
Feel free to use my second attempt which includes more detail. V - Applies SX 1 July to 27 September. Not advertised from Preston.THat picture appears to have clipped off too much to have any useful information
