Legionella Outbreak - Edinburgh
route:oxford
1 Nov 2008
It occurred to me whist reading about the Legionella outbreak in Edinburgh that the outbreak zone isn't far from the Railway.
Clearly trains have air-conditioning systems and other cooling systems on board.
So...
Is it possible that the outbreak in Edinburgh could have been caused by a rail vehicle?
Oliver
17 Aug 2007
So...
I believe the virus grows in water cooling systems open to the atmosphere, (e.g. tradition cooling towers) not in closed-circuit refrigeration systems used in car or train air-con.
myboysam
11 Aug 2011
Oh, here there and anywhere
If it was caused by a trains air con then I'm pretty damn sure a lot more people would have been 'infected' and when they investigated there would be a theme amongst the sufferers.
142094
7 Nov 2009
Newcastle
I would have thought it will have been quite obvious if there was a lot of sudden sickness amongst staff.
paul1609
28 Jan 2006
Wittersham Kent
So...
No, but all steam railways should have a plan in force for their water towers which could present such a risk.
JGR
31 Jan 2012
Ipswich
The water in steam railway towers is going to just get boiled, condensed and ejected into the atmosphere (thereby killing any such pathogens) and hence there is no such risk.
It is not used as part of the processing of air for use by the staff/passengers, and no-one is going to stick their head into it in the tower.
TBH I'd expect most modern and all mobile cooling installations to just use a proper refrigerant along the lines of R134a.
scotsman
6 Jul 2010
Old news. A huge amount of people became ill over a sustained period throughout a large area, implying that a static object producing a high quantity of vapour was the cause. This left a handful of facilities in the area which could have caused the outbreak.
michael769
9 Oct 2005
The problem is not with the steam engine emissions which as you say are effectively sterilised, but with the potential for a colony of legionella to grow inside the tank and pipes. In this case the water towers are generally outdoors and as such for much of the year are below the 25degC minimum at which colonies can grow.
Cooling towers are a major risk as many do circulate water in the 25-45deg "danger range" when rapid colony growth can occur and the towers release aerosol clouds into the local area which if infected can present a real danger to the public as well as staff. This is still believed to be the source of the Edinburgh outbreak, and it is notable that as soon as the suspect towers were sterlized the outbreak died down.
Beyond cooling systems any indoor storage of non-treated water (commonplace in commercial and industrial buildings) at room temperature or above (25-45degC) is a potential risk, albeit (assuming there is no mechanism to create an aerosol cloud) only to staff and occupants. There have been a number of cases traced back to infected shower or washing systems, and as a results such systems need to be tested annually. One should never drink water from taps in commercial and industrial premises without first confirming it is drinking water as ingestion does present a low risk.
Our domestic water tanks (and indeed any drinking water system) should be safe as the public water supply is treated with either cloramide or chlorine either of which kills the legionella bacteria.
For rail the engine coolant and steam is far too hot and the air conditioners use refrigerants rather than water. The only potential source would be the water supply for the toilets, but hopefully that is managed by treating or regular testing. Even if infected there is no mechanism for the bacterial to be released into the wider environment so the infection would be limited to passengers and staff.
p123
1 Oct 2011
So does anybody remember this (see link below)?
Just to be clear, my opinion on this story is that I'm 100% sure it has absolutely nothing to do with the Edinburgh outbreak, given that all the victims reside in the same area of Edinburgh - and there ain't no way they were all on the same train at the same time!
But, topical given the line of discussion.
http://www.bbc.co.uk/news/uk-scotland-13593399
