Leominster to Five Ways with Anytime Return (+16-25 Railcard) via Any Permitted Route - Permitted via Shrewsbury in disruption?
ddalistic
14 Oct 2020
Herefordshire
Good morning,
I had a conversation on Monday with Customer Services for West Midlands Railway, after the 12:56 Five Ways - Hereford train was cancelled.
My question was: because of the cancellation, is it permissible for me to travel via Shrewsbury (the 'via Craven Arms' option).
He kept saying that because the ticket had no route restrictions, I was free to travel that way. However, I know that both National Rail Enquiries and Trainline say that it isn't a route you can take with that ticket.
Does anyone have any advice about this? If indeed the ticket is always valid on that route, I'd prefer to take advantage of it. I've checked the fare check rule and it seems to comply. But I also don't want to risk a penalty.
I make this journey on Mondays, Tuesdays, and Thursdays. As it's a long journey I don't want to make it longer.
Thanks in advance,
David
JB_B
27 Dec 2013
I think Craven Arms fails the fares check as an origin routeing point for destination routeing points Birmingham Group and Barnt Green.
That's right
Leominster to Dudley Port is OK via Craven arms as that's the shortest route.
Haywain
3 Feb 2013
Should you wish to travel via Shrewsbury, you can buy a ticket routed 'via Craven Arms' which is valid for travel that way. It is, unfortunately, more expensive than the ticket routed 'Any Permitted'.
ddalistic
14 Oct 2020
Herefordshire
Are you able to show your working for this?
I just put it in to National Rail Enquiries again and realised I'd made the error of comparing single fares to/from the routeing point with the return fare for the whole journey (facepalm)... Sorry about this. It does indeed violate the fare check rule.
Should I conclude from this that the WMR customer advisor didn't know his stuff?
David
moose5000
26 Jun 2019
I'm pretty sure as well that if for whatever reason (e.g. cancellation, delays) West Midlands Railway says you can travel via Craven Arms and Shrewsbury on the Any Permitted ticket, then you can. I'd recommend getting an endorsement for this just in case West Midlands Railway haven't cleared it with Transport for Wales - then any problem is between the two operators.
ddalistic
14 Oct 2020
Herefordshire
Thanks. This is what I regretted after I put down the phone -- he asked for my email but I didn't get an email confirming our conversation and what had been said. In the event, though, my ticket wasn't challenged.
1955LR
11 Dec 2019
Hereford
I have on a couple of occasions travelled via Shrewsbury BHM to HFD when WMR trains cancelled at short notice last year , on advise from staff at BHM . Also walked over to Moor St instead, depending on timings of alternative trains.
JB_B
27 Dec 2013
I just put it in to National Rail Enquiries again and realised I'd made the error of comparing single fares to/from the routeing point with the return fare for the whole journey ....
One thing to keep in mind is that the fares check is based on the fares at privatisation ( NFM96 ) - using current fares may not give accurate results.
You can check the appropriate routeing points using the routeing point calculator at http://data.atoc.org/rp_calc ( when it's working!).
